xm radio install? Diy?
Old Nov 27, 2005
StealthCivic's Avatar
StealthCivic is an unknown quantity at this point
Is there a diy for installing xm radio? I need to know how to/where to put the atenna for reception. Thanks. I searched a good bit ......
Old Nov 27, 2005
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
I posted a diy for installing a hideaway pioneer xm tuner, search by my username
Old Nov 27, 2005
starstryke's Avatar
starstryke is an unknown quantity at this point
You using an aftermarket deck?
Which make... or rather, look in your instruction manual.
If you have a spoiler mount the antenna through one of the holes (I chose the right side since the XM hardware fits nicely behind the glove box (tape it down). You might have to break off a retaining clip on the antenna plug to fit it through one of the holes but it stays put. Now my XM antenna is neatly tucked by the Spoiler.
hope that helps a little.
Keep in mind I bought the Sony XM reciever from Best Buy so it was a little easier.
Old Nov 27, 2005
I searched for your diy and couldn't find it man, I have a stock cassete/cd honda oem tuner, I will plug the cassette into the deck to play xm that way...my main question is 1. where to mount the antenna 2. how to run the antenna wire
Thanks.
Old Nov 27, 2005
CraigW's Avatar
My sedan has it on a pedestal I made, inside on the back deck. For a coupe that could be trouble. I had thought about searching out a good suction cup set-up as a possibility.
Old Nov 28, 2005
http://www.7thgencivic.com/forums/sh...ad.php?t=97887
its written for an older xm tuner, but the steps are basically the same
Old Nov 28, 2005
thefivespeeder's Avatar
thefivespeeder is a jewel in the roughthefivespeeder is a jewel in the roughthefivespeeder is a jewel in the rough
mount the antenna with 22degrees vetical clearance and on no more than a 10degree horizontal plane with 2square feet of metal below the antenna -striaght from the MECP basic install manual- mount it on the roof, unless you have a convertible then you mount it on the trunk lid
Old Nov 28, 2005
formulad97's Avatar
formulad97 is an unknown quantity at this point
put my antenna on my roof centered over the windshild and ran it down the gasket to the engine bay , and came in where my amp power goes through the fire wall. I didnt want to use the rear of the roof because of the gasket one the rear window had a small gasket and i seem a little brittle.
Old Nov 28, 2005
nick95673's Avatar
nick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to behold
its really worth paying the 40-70 bucks to have the antenna installed by a pro. i have seen people who diy'd everything on their car and do it well. show up at the audio shop i worked at with the antenna wire not even in the window molding and their paint scratched to hell. pay to have it done if you install the antenna on top of the car which is the best way to do it.
Old Nov 28, 2005
couldnt agree more, when i did it on my car 3 years ago i scratched my paint really bad. Now that im doing at least two a day its not an issue
Old Nov 29, 2005
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
I put my XM antenna UNDER the 3rd brake light. Works great and is invisible.
Look in my ride.
Old Dec 2, 2005
AggressiveAdam's Avatar
AggressiveAdam will become famous soon enoughAggressiveAdam will become famous soon enough
ideally you place your antenna on the roof, however now that they have repeaters where I live in Toronto my brother got away with putting it on the back window tray
Old Feb 5, 2006
gotricebrother's Avatar
gotricebrother is an unknown quantity at this point
xm radio
i have the pioneer avic-n2 and just got my xm radio unit the gex-p920xm installed at a shop. when i got home and went online to activate my xm i looked at the screen on my deck and it said no connection/no signal, but i can hear the xm preview channels like 00,01. so i was woundeing did the shop not connect it right or is there something else for me to connect. need help asap.
Old Feb 5, 2006
you can hear the audio while the screen says no connection/no signal?
Old Feb 5, 2006
fiatdale's Avatar
fiatdale will become famous soon enoughfiatdale will become famous soon enough
If you can hear the preview channels, then you need to take the ID number from channel 0 and use that to activate it. They have been slow lately. Go activate it, then leave the vehicle on after about 15-20 minutes of activating, or drive around a bit. It will register and youll be golden.
Ill take pics of my XM antenna, its roof mounted. The cable is so thin that it is very easy to run it in the rear window molding with a pick tool. Then just run it into the trunk and to the tuner pack (wherever yours may be installed.
Old Feb 5, 2006
thatsmrgimp2u's Avatar
An elephant.... with stamps for hands.
thatsmrgimp2u is an unknown quantity at this point
If you can hear channels 1 and 247 they hooked it up just fine. It takes anywhere from 15minutes to an hour to receive a signal though (with your avicn on). I mounted my antenna on my trunk lid close to the brake light, and ran the wire in through the trunk that along its hinges, then tucked it all the way to the head unit. I think it looks good there.
Old Feb 5, 2006
fieryhill's Avatar
fieryhill is an unknown quantity at this point
beat me to it lol i was excited because i actually knew something useful
Old Feb 5, 2006
i can't believe this. I did mine in maybe an hour or two because it was freezing cold and i took my time getting everything setup and wires run to the battery.
Here is my quick diy:
1: run two wires out to the firewall from center console. connect one to battery (at the end), and the other to a chassis ground (now).
2. pull out your radio center piece and plug the connector to the back of your radio (assuming you have aftermarket, its gonna be ainet, ipbus etc).
3. run that wire to the receiver and plug it in. I opted to put mine under the ebrake housing for a hidden install yet still have easy access.
4. run the power and ground through the center console and connect to the receiver
5. plug the antenna and run it out the back of the console, under the carpet, under the rear seats, around the rear of the trunk, and put it over the molding. now the problem i ran into was the metal had a groove that the molding sat in. if you just run it over that and push the molding down, you are gonna smash and possibly damage the wire. So I did something stupid and hacked out a giant hole because I ran the wire already and didn't wanna take it off again to start over. So it leaked like a ****. Finally I got it sealed using huge blobs of silicone. i would suggest drilling a small hole rather than carving out a huge piece and then run the wire first and using a drop of silicone to seal up.
6. run the antenna wire under the molding. i used a key to pry up a bit at the end and stuff in the cable. at the top i cut a slit in the rubber so the antenna wire doesn't look curvy.
7. press the reset button on your HU and you're all set. follow instructions on setting it up.
i really dont think this is something you should pay to get done unless you have no clue about what a wire is or simple things on how your car comes apart. oh and i'm not sure how you guys are using the amtenna hidden under the car or in the dash or whatever. i tried hiding it but the reception was alot worse (if thats possible, its pretty bad when installed the right way too). The rear deck seemed like the best place but with my tint i was getting static. So out it goes. if you do it right, it shouldn't look that bad.
Old Feb 5, 2006
fieryhill's Avatar
I pretty much know nothing about wiring but I'm here to learn! My dad knows a lot too but, he tried helping me with it but he got frustrated with my "foreign car", he wanted to have a fuse for it, but he didnt want to run a fuse from the battery through the firewall, so I just went and had it installed, plus neither of us want to break stuff, and if they break it they have to fix it.
Old Feb 5, 2006
oh crap lol. i forgot to put a fuse on the power wire oh well
Old Feb 5, 2006
fieryhill's Avatar
Old Feb 5, 2006
fiatdale's Avatar
Where Gearbox has his antenna is the same as I have mine. Mines an XM antenna (not that it matters one bit) and mine is also painted. see:
Old Feb 5, 2006
how did you paint yours and still get good reception? or did you buy a painted one already?
Old Feb 5, 2006
as long as the paint isnt a heavily metalic based paint, the reception wont suffer. I know i saw a dealer on xmfan.com that sold them, he even matched it to your exact paint code, someone prob sells them for sirus too.
Old Feb 5, 2006
fiatdale's Avatar
Yeah, as long as there isnt much metallic in the paint, no problems what so ever. Im not sure how they are doing it on the 06 civics, becuase they are all painted, but whatever works.
Old Feb 5, 2006
CraigW's Avatar
Both of those antenna installs look great !! I made a pedastal and put mine on the back deck, works great from inside.
Not sure about the coupes, but be extra careful with the sedans. The trunk hinges will damage the wires easily with out wire looms being used.
Old Feb 5, 2006
i guess thats why satin silver metallic won't work
Old Feb 5, 2006
MegaHurtz's Avatar
There are already diy's out there, greenloch kindly pointed you to one, search next time please
GolNat
Suspension DIY
May 12, 2022 06:49 AM
Youshoe
May 22, 2015 09:36 PM
Ian SFBA
Interior DIY
Apr 25, 2015 02:25 PM
toastyghosty
32
Dec 26, 2001 02:03 AM
ROBREALZCIVIC
Nov 16, 2001 06:53 PM
