Making an on/off switch for my subs???
Old Nov 21, 2005
stupidspoons's Avatar
stupidspoons is an unknown quantity at this point
Can someone help me out with this?
I want to make a switch that is going to the subs i have in the trunk of my car so that on my bad days i dont have to hear them rumbling all the time or when i have to drive my parents somewhere because they hate it.
Which wires could i put a switch for?
and if this is even possible?
Old Nov 21, 2005
nick95673's Avatar
nick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to behold
yes buy a cheap switch from any hardware store. just splice it in to the blue remote line on the back of the head unit.
Old Nov 21, 2005
xDCx's Avatar
xDCx will become famous soon enoughxDCx will become famous soon enough
sure its possible. but id say just get a deck that has that feature, most headunits do that ya kno...even thecheap ones
Old Nov 21, 2005
2k2_civic_ex_4d's Avatar
2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold
Yeah I agree do it this way. My brother and friend did it in there own cars. it's better than having the feature on a deck that can do that. Funny things most people will think it's for something secret or special, just tell them that bad things will happen if they push it.
Old Nov 21, 2005
MegaHurtz's Avatar
Ive never seen a deck that allows you to turn the sub or any of the preouts off, and i've owned and used a lot of decks.
jsut put a switch on your remote wire assuming you only have the 1 amp. I have one in my car under my dash on the drivers side
Old Nov 21, 2005
nick95673's Avatar
my alpine cda9847 has it. but personally i like the switch more. its a hidden feature. not hard to find but a switch is that much quicker.
Old Nov 21, 2005
xDCx's Avatar
ohh my alpine does it
Old Nov 21, 2005
AzNmiKex215's Avatar
2k1civic.com O. G.
my pioneer headunits had it. From the 6400 to the 8600.
SubWoofer On or Off.
Old Nov 21, 2005
eye_see_you's Avatar
let the devil out
the subwoofer off function in most cases just turns down the output for the sub but in some cases turns the whole option off. A switch to the remote wire in most cases is the option
Old Nov 21, 2005
Bad_Civc's Avatar
If Your Reading This Your Dee Dee Dee
Bad_Civc is an unknown quantity at this point
my panasonic deck does it... sub control ...
off -6 -4 -2 0 +2 +4 +6 ...
i can turn em off or turn em on ..
Old Nov 21, 2005
CenZ's Avatar
PWIT
either way i think the best way is the switch, its faster too. like if you roll into the mall. you can flick a switch and bam no more bass, instead of playin with your HU til you get to the setting to turn it off.
Old Nov 21, 2005
Mike04Civic's Avatar
Mike04Civic is an unknown quantity at this point
yeah, its possible...just put some sort of toggle/power switch between the amp and the battery....
although,...the pioneer 6700 h/u has this feature (on-off switch for subs) "easy access" to, no going through a million diff settings...
Old Nov 21, 2005
05reverb's Avatar
05reverb is an unknown quantity at this point
every HU I saw with a sub preout, had that feature, but switch is better because it's faster to turn it off and turn back on, plus it shuts down your amp as well, cause when shutting it off on the HU, it only stops the signal going through your sub out, so the amp stayes on.
Old Nov 21, 2005
dp_yz713's Avatar
Boobies are the mans tinkertoys
dp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to behold
deffinately the easiest way. had it in all my cars so far
Old Nov 21, 2005
usafcushman's Avatar
7thGen's Loudest Civic...4,000 watts and climbing...
usafcushman is on a distinguished road
i have my amps, L.E.D.s, etc. all run off of one switch mounted on the dash... that way when i go through the ECP on base, or get pulled over, i just hit one switch and everything shuts off except my head unit and door speakers...
i ran mine to a relay, since it's going to more than one component, but you get the idea... there a million pages that show how to hook up a relay and/or a switch (most of the time the instructions are even on the product packaging), but just holla if ya need any help... hope this helps... good luck!...
Old Nov 21, 2005
dp_yz713's Avatar
Nice set up. I like
Old Nov 21, 2005
'preciate it... the switch is mounted a little off-center in the dummy panel in the dash, but i've never noticed it until i looked at that pic lol...
Old Nov 21, 2005
jay78's Avatar
jay78 is on a distinguished road
just do as lots of members said.....put the switch between the remote wire which is blue....i have mine under the staring wheel...
mistermenphis22
Apr 3, 2016 08:06 AM
Star1967
May 3, 2015 09:09 PM
alexkharden
Apr 23, 2015 07:13 PM
dooner24
Apr 14, 2015 07:51 PM
nickfn
Nov 8, 2001 09:44 AM
