Wires for what?
Old Nov 15, 2005
starstryke's Avatar
starstryke is an unknown quantity at this point
Wires for what?
I bought a Bazooka Scuba8 for my vic and well, it only has two wires to connect to who knows what.. A blue one and a red one.. I was wondering if the uh red one is the power cable but that would only leave 1 cable for audio.. so now I wonder if I have to connect it directly to an amp... anyone know how to hook this sub up?
I also want to know a safe place to secure it in my trunk, was thinking on the passenger side and bolted down to the body, this a safe spot? any obstructions or anything dangerous I could hit while screwing down the mounts?
Old Nov 15, 2005
starstryke's Avatar
bump
please, when it comes to audio I'm clueless. At least with this woofer since it supposedly has a prebuilt amp inside already.
Old Nov 15, 2005
ramcosca's Avatar
Words on a User Title
I know I'm getting out of topic here... but why did you get the boat subwoofer? Is your car white?
[EDIT]... ok... nevermind... still a boat sub but it's not the white ones, my bad. You scuba dive?
BTW, I don't, but my ex-neighbor does... he's an underwatrer photographer...
Whoa... went out of topic... REAL bad! Sorry!
Old Nov 15, 2005
starstryke's Avatar
I'm a surfer so I needed something water resistant since I throw my wetsuit there after a long session.
Old Nov 15, 2005
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
i tried searching for the manual online but couldnt find it, could you get a picture of the connections coming off the unit?
Old Nov 15, 2005
coop's Avatar
coop is a jewel in the roughcoop is a jewel in the roughcoop is a jewel in the rough
Is your bazooka preamplified? (sounds like it) if so, I believe what you have are power and ground leads......
Old Nov 15, 2005
starstryke's Avatar
argh, ok, no camera to be found atm.
one blue wire, one red, no other external cables otherwise this install would be easy.
read on the generic 'system features' section of the instruction manual that it has a COPLANAR OUTPUT... whatever that is.
I might just give their customer service a call.
Old Nov 15, 2005
starstryke's Avatar
ack, gonna give em a call later... have a tv to build.
Old Nov 15, 2005
leviathan18's Avatar
leviathan18 is an unknown quantity at this point
red is power blue with a white stripe is control it sould turn on the amp of the sub at the moment you turn on the car im just guessing by the colors
Old Nov 15, 2005
Kyle23's Avatar
Kyle23 should not be trustedKyle23 should not be trusted
If its the size of a speaker wire than u have a positive and negative and u just need to splice them in with ur rear speakers already existing wires and they will work off of that.
Old Nov 15, 2005
starstryke's Avatar
interesting, wonder if I should try that.... any other comments on what kyle said? If that's the easiest/best way to do I'll do that.
The blue and red wires have no stripes or markers, just plain.
Ok, back to work.... argh.
Old Nov 16, 2005
coop's Avatar
does the sub have an amplifier in it? some bazookas do, some don't. If it has an amp built in you have power leads if it does not then it needs to get hooked up to an amp.
Old Nov 16, 2005
i cant see it being a powered speaker if it only has two connections. It would need at least four, 2 for inputs and 2 for power
Old Nov 16, 2005
Kyle23's Avatar
"Without question, the wildest & most original subwoofer enclosure design in the history of car audio. Strap this monster in your ride for a quick & easy Bass Boost. Use it alone, in pairs, or even mount it next to your existing Nitrous Oxide system. This 8” subwoofer is simply a Bazooka subwoofer w/the patented Bass Tubes enclosure camouflaged to look like a Nitrous bottle. This unit comes complete w/tank, cosmetic nozzle, braided line speaker wire, & a complete mounting kit.
* Power Handling 6 - 300 watts * Impedance 4 ohm * Sensitivity 102 db * Frequency Resp. 39 - 1500 hz * Recommended Power 150 watts (rms) * Voice Coil Size 2"
Cliff notes: U need an amp with atleast 100w RMS but shouldnt be more than 175w RMS x 1 at 4ohms.
And u need a wiring kit for the amp and a LOC if u have a stock HU. (line out convert( hooks up to rear speakers)
Old Nov 16, 2005
that makes more sense
Old Nov 16, 2005
starstryke's Avatar
yeah, will do, will be back later
SimpleUser
Apr 24, 2021 02:54 AM
Kevinsisco
Aug 31, 2015 12:04 AM
sch2cm
Jul 21, 2015 09:58 PM
CivicsClass101
Jul 9, 2015 11:14 AM
robbie374
Jul 7, 2015 02:56 AM
