04' accord
1-look an accord!
2-remove the shifter bezel by prying it out with a screwdriver.. you might want to wrap it in a cloth to keep from scratching stuff
3-as you can see there are 6 clips.. 2 on the bottom.. 2 in the middle.. 2 on the top
4-see toldja
5-this is what it looks like when you lean in closer
6-pop out the change holder.. as you can see there are 2 clips.. one on each end
7-see toldja
8-this is what it looks like when you lean in closer
9-more stuff to pull out
10-more clips on the ends
11-disconnect the lighter thing
12-remove the screws.. be sure to hold them with something cuz if you drop them you will have to take apart the center (or just pry the bottom out till the screws fall out)
13-yay no more screws!
14-PULL SUCKA!
15-careful though theres 2 clips at the top so pull straight back dont pry up
16-put the flip pocket on the floor so you dont lose it
17-thats the top.. cool huh
18-
ok its dinner time ill be back
4-see toldja
7-see toldja
14-PULL SUCKA!
18-
18-do the screwdriver trick again under the vents
19-theres 3 clips along the bottom
20-pull the top piece off
21-owww a plug!
22-take out the screws on the top of the headunit
23-pull
24-now go backwards real fast and everything will be all better
21-owww a plug!
23-pull
I spend way too much time on this website
Originally Posted by blue_dlb
Originally Posted by RS4DUKE
that is helpfull but is there anything that tells you the directions?
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
beanhead
Sep 24, 2015 12:04 PM
Bikergofast
Sep 12, 2015 01:36 PM
