Dimmer Wire/Illumination Issues?
Old Aug 1, 2005
Taffy's Avatar
Taffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant future
Question Dimmer Wire/Illumination Issues?
I just put a new deck in and I hooked up the dimmer wire (orange/white) on the Honda Wiring Harness because the Pioneer deck had a dimmer wire (orange/white). Now by doing this the buttons will light up when you switch the parking lights on even when the deck is turned off. For some reason the lights on my deck flicker continuously when I do this, but lights up perfectly fine when I turn the deck on. Could this be a defect or is the orange/white wire on the Honda harness not the right one (there's a solid orange on also) ?
Thanks
I feel dumb.
Old Aug 1, 2005
MegaHurtz's Avatar
try the solid orange...
Old Aug 1, 2005
AlienX's Avatar
AlienX will become famous soon enough
seems like it would be a problem w/the deck. Contact pioneer about this, the illumination wire is a constant, which should'nt cause this.
wiring diagram
http://www.7thgencivic.com/forums/sh...d.php?t=153833
says black/red but this doesnt seem right to me. I think i remember connecting mine to something orange also
Old Aug 1, 2005
tony_buttons's Avatar
I'm unusually bored.
tony_buttons is an unknown quantity at this point
I dont think I even used the orange wires...
Old Aug 1, 2005
Kyle23's Avatar
Kyle23 should not be trustedKyle23 should not be trusted
I didnt need them either cuz they didnt match up so I just capped it off. My apline works fine w/ or w/o the lights turned on. I say recheck ur wiring
Old Aug 1, 2005
Taffy's Avatar
Megahurtz was correct. Just because the colors on the wires match up, doesn't mean they actually match up. Solid orange was illumination, and Pioneer it is Orange/white so read the packaging.
Thanks man, Repped!
Old Aug 1, 2005
Reason its flickering is your illumination ****. Adjust it left or right at it will stop flickering.
Old Aug 1, 2005
Taffy's Avatar
The little **** in the instrument cluster is the dimmer switch, that's what I hooked it up to before and that's why it was flickering. But I hooked up the illumination wire, and it is fine.
civic_gt
Apr 19, 2015 08:15 AM
mohawkboom
32
Oct 9, 2006 02:49 PM
Chlorine
Mar 19, 2002 08:26 PM
PiCASSO
Mar 10, 2002 01:34 PM
Sarvic
Mar 5, 2002 07:22 PM
