trunk idea
Old Aug 1, 2005
sittinon17s's Avatar
sittinon17s is an unknown quantity at this point
trunk idea
i have a good idea for how to do my trunk up, but i need a new floor to it. i was going to fiberglass the trunk then take a measurement of the very edge of it, but thats not real accurate or practical. if anyone has any way of taking an outline of the trunk i would appreciate a suggestion
Old Aug 1, 2005
Rufus's Avatar
cardboard taped together. look at the pics in "my ride" section.
Old Aug 1, 2005
thats almost exactly what i want to do but with wood. i looked at the DIY for a custom sub trunk, but he says trace, well, wtf? what do i trace on? do i just tape the cardboard together and fold it up?
Old Aug 1, 2005
Rufus's Avatar
lol Mine IS wood. It's just wrapped with suede. You can always trace that crappy trunk particleboard that comes in your trunk but otherwise you tape small pieces of cardboard together on the outsides and then you can fit larger ones on the inside. The point it that you could not fit the piece as an entire piece of wood in and out but cardboard you can fold. So you pull it all out, trace it out on wood and then cut it into small enough pieces to get in back into the trunk as wood. Look at mine. It's 3 pieces.
Old Aug 1, 2005
nick95673's Avatar
nick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to behold
once i had the large center parts in i just put a piece of paper in the trunk and cut the shape with a razor blabe then used it as a template. if it didnt fit i grabbed the jig saw and cut the wood down a lil more. very simple. just dont fear wood working. but respect the tools
Old Aug 1, 2005
PopcornPlaya's Avatar
Electric Boogaloo...
trace the stock piece of carpet
Old Aug 1, 2005
Rufus's Avatar
good idea too
Old Aug 1, 2005
MegaHurtz's Avatar
the stock carpet or the board that comes in your trunk might not be a perfect fit but you can use it as a start to cut your wood out. easiest thing to do I think would be to take the board and having it laying in your trunk, mark the areas where you need to change the shape (add to the template) and then just draw that in when you trace it out on to the sheet to be cut. it might not be perfect the first time, but cut it down a couple times and it should fit really well.
Old Aug 1, 2005
my stock carpet was a perfect template. I beveled the top edges so it didn't stick up. I'm sure that not everyone's carpet is the same though, and some won't be a perfect fit.
Old Aug 3, 2005
WhiteRabbit's Avatar
if your stock carpet isnt a fit, the cardboard is a great idea
when I do it, I cut it into strips, then push it up agasint the edge, and staplegun it to a scrap of wood. when I pull it out, its a perfect contour at the height I need of the floor I want to make.
Old Aug 4, 2005
the other day when i posted this i tried just making a basic shape, with basic measurements, but since its slanted and theres that one strip of off white caulk crap that makes it wider than whats beneath it. i dunno, im gonna try it again but ill measure it 10 times before i cut it this round.
and when i cut it in half to fit it in, it fell inwards, i guess i'd have to lay another board across the top and bottom to keep it straight. if all else fails i could always fiberglass it, that shouldnt be too hard, just $$
Old Aug 4, 2005
dont cut it in half. that will leave an ugly seam right on the middle for all to see.
by making two seams, one to either side, noone is the wiser. it also simplifies your work. you have one "main" piece that is as wide as the narrowest part of your trunk. the sides will be straight, and the cabin boundary will be straight, you just have to cut an arc in the back where the trim that covers the latch is. Once that is in place, you can use the cardboard trick for each side. each seam will be peftectly straight and ideal for a "carpet hinge" so to speak.
seamless floor. OEM look. perfect.
Old Aug 4, 2005
Rufus's Avatar
check my pics i put 2 seams in
DerbyDad03
Exterior
May 16, 2021 10:07 AM
Jeffdp
Aug 5, 2015 11:38 AM
cperez53
Apr 16, 2015 09:31 PM
djdefcon
17
Apr 6, 2005 11:52 PM
