Alternator for 03 Civic LX Sedan
Old Jul 14, 2005
suthurnlatino's Avatar
suthurnlatino is an unknown quantity at this point
My Civic says its manufactured in Canada when I go to Carfax. Will this make a difference if I try to buy a HO alternator?
Old Jul 14, 2005
CraigW's Avatar
First letter of VIN, 2 = Canada / 1=U.S.
You may need the engine code.
Old Jul 15, 2005
How do I find out the engine code? Carfax says I have a 1.7L L4 SOHC PFI 16V engine Manufactured in Canada (My VIN does start with a 2). My problem is that alternator makers online say the HO alts do not fit the Civics made in Canada.
Old Jul 15, 2005
CraigW's Avatar
D17??? On my 05 it is stamped into the block right beside the VIN tag on the engine. And also on a white tag on the timing belt cover. (there may be other places)
Old Jul 15, 2005
dma001's Avatar
dma001 is an unknown quantity at this point
Well, I think that would mean that this particular HO alternator will not fit sedans -- I could be wrong, of course, but I believe the Civic sedans are assembled in Ontario, Canada, while the coupes are built in Ohio. (My sedan is Canadian, dontcha know... )
Old Jul 16, 2005
The dealer told me " The Canadian alternators are not available. I cannot build one for you unless you send me the one on your car or a Canadian alternator to build. Can you send me some pics of the one on your car so I can see what the difference is in them ? I might be able to get one to work....?" I wanted to know if it made a difference if my car was manufactured in Canada or not since on EBAY I see a listing that said NOT FOR CIVICS MANUFACTURED IN CANADA. Where did you Canadian-built Civic owners get your HO alternators?
Old Jul 16, 2005
dma001's Avatar
That's odd. When I got to Majestic and compare the OEM (Mitsubishi) alternator for a 2003 LX sedan to that of a 2003 LX coupe, the part numbers seem the same... I don't get why the HO alternator would not fit both vehicles.
kanin247
Bolt-on Engine Performance
Apr 25, 2015 05:44 AM
Civicchicky87
Idle Issues
Apr 22, 2015 07:16 PM
smmahan
Apr 15, 2015 08:17 PM
dano2005
Apr 14, 2015 01:58 AM
aus10
Apr 13, 2015 09:26 PM
