rolling sub box
Old Jul 13, 2005
AnaRki's Avatar
DDC Representa
AnaRki is an unknown quantity at this point
rolling sub box
quick question, my sub box always rolls around in my trunk and its pretty annoying. what should i use to hold it down? Ive already tried velcro. thx
Old Jul 13, 2005
half_n_half17's Avatar
half_n_half17 is an unknown quantity at this point
I screwed small brackets into the cardboard floor around my box. It doesn't move around much.
Old Jul 13, 2005
MegaHurtz's Avatar
velcro holds pretty good if you don't haul *** around every corner
Old Jul 13, 2005
tbaleno's Avatar
tbaleno is an unknown quantity at this point
how about those pads you put under rugs to prevent them from moving around.
Old Jul 13, 2005
ragingSPAM's Avatar
I just burnt my tongue
heres what my friend did...on the back of the sub box he put on 3 loop type hooks on the back of his subbox than he got a black rope/bungeecoard of some sort which u could barely see and tied it down to the rear panel above the sub box where the stock speakers sit...and it doesnt move at all and if he wants to move it he just un ties/hooks it and bam there u have it
Old Jul 13, 2005
tony_buttons's Avatar
I'm unusually bored.
tony_buttons is an unknown quantity at this point
yeah I was going to say bungees
Old Jul 13, 2005
pr0vidence's Avatar
pr0vidence is an unknown quantity at this point
I just made the box big enough to span with width of the trunk and put my amp on it no problems.
Old Jul 13, 2005
bangemsmurf's Avatar
bangemsmurf has a little shameless behaviour in the past
put l shaped brackets into the box in the front thats wat i did wit mine and it never moved again
Old Jul 13, 2005
PunkingCivic's Avatar
I need TP for my bunghole
have a rear strut bar?
then make a bracket on each side that connects to the box and the strut bar
Old Jul 13, 2005
4Saris's Avatar
4Saris is an unknown quantity at this point
Carpet Tack Strips on the bottom. They sell them at your local Home Depot for $1 each. One side goes into the box, the other sticks to the carpet.
Old Jul 14, 2005
PopcornPlaya's Avatar
Electric Boogaloo...
Replace the cardboar crap floor with MDF. Unload (remove the sub) from teh box. Screw it to the floor through the bottom of the box from the inside. Reload sub box. If you don't want to do that, still replace the trunk floor then use L-brackets.
Old Jul 14, 2005
zen_master's Avatar
this is very interesting! im also annoyed by the fact that it always move around..
i ended up using the anti slip pad......big one....bought from wal-mart..
i put it underneath the carpet.......however, if i made sharp cornering, it'll still move around a bit.....
what is MDF?
Old Jul 14, 2005
Medium Density Fiberboard. The same thing your sub box is constructed of (most likely).
Old Jul 14, 2005
zen_master's Avatar
is it available for our vic...or do we have to cut it ourself? =) hehe
i've to say that the board right now sucked...it's to thin....it's also kind of bended by the sub box
Old Jul 14, 2005
x25xtalife's Avatar
x25xtalife is an unknown quantity at this point
Build A Floor Out Of Some Plywood Or Mdf And Screw The B*tch To The Floor.......not Rocket Sience
Old Jul 14, 2005
cubanmike26's Avatar
They sell MDF at TheHomeDepot & Lowes and tehre's also a DIY made by Diskreet for a custom trunk floor.
Old Jul 14, 2005
zachgeyer's Avatar
into the fram
robjcivic
Mar 12, 2017 12:10 PM
Raiool
Oct 1, 2015 10:42 AM
Tedverseti
Sep 29, 2015 05:41 PM
Hutch1051
Sep 29, 2015 09:20 AM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
