need advice with sub/amp combo..
Old Jun 14, 2005
blouisgod's Avatar
Life Begins > 6800rpms
I searched and read a lot of articles and posts but i need some buyer experience with this. i have had 2 rf 10s for a while running on 250rms that i got a way long time ago. i had to sell them cause im moving and dont have the space for them.
within the next month, im thinking of getting a single 12 and running 500rms to it courtesy of my current amp. im thinking, from what ive read, getting a decent 12" with high sensitivity and 4 ohm, maybe dual voice coil? got any recommendations? im trying to stay under 150 or so and have been looking at some audiobahn subs. either those or infinity kappa perfect if i can afford it, maybe JLs?
got any suggestions? im kinda confused about 2/4/8 ohm and running an amp to it, and also the DVC issue and how to wire it up. ill take any advice you guys can toss a newb when it comes to trunk ice
Old Jun 14, 2005
Kyle23's Avatar
Kyle23 should not be trustedKyle23 should not be trusted
would u be willin to buy from ebay? I would probably go with an Alpine Type R. New they're like $200 so I dont know if that would b out of ur range but they will handle the power pretty well. DVC = dual voice coil and that just gives u more wiring options. With a DVC u can wire ur sub down to half the resistance if ur amp can handle it. Example 4 ohm down to 2 ohm. Those Kappa Perfects r also pretty good, I believe that there db = 94 which is reall sensitive for a sub. those r like 300rms and 1200peak but is should be ok if u turn down the gain on ur amp. Anything else? Let me know...
Old Jun 15, 2005
blouisgod's Avatar
What do you mean?
Tyler93
Mar 20, 2016 09:03 PM
2002ExCivic
22
Sep 28, 2015 08:29 AM
PunX
Sep 23, 2015 10:45 PM
sf3r8z
Sep 23, 2015 03:26 PM
bhollie
Sep 22, 2015 11:08 PM
