Ground melted
Old Jun 4, 2005
Supermanrider's Avatar
I dont know what im talking about
Supermanrider is an unknown quantity at this point
Ground melted
hey everyone my ground melted on my amp it was the connection on the amp it was gettin so hot that it melted the plastic surrounding the ground what is the cause of this
Old Jun 4, 2005
ex_03's Avatar
Godlike member
ex_03 is on a distinguished road
Holy christmas, Start over...Need some info??? Powerwire size, where its ran to, how longs the ground, where its grounded to? bring it!
Old Jun 4, 2005
yeah i know big trouble in my trunk.
4 gauge 100 amp wire kit, positive from battery, ground is no more then 10 inchs, grounded to bare metal right behind the seat that bar inbetween the trunk and the seats, o and i brought it.
i just got it installed in feburay would they fix this problem for free
i would hope so for my sakes i really dont want to buy a new amp.
Old Jun 4, 2005
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
is the ground location sanded down to bare metal? It sounds like the ground point has alot of resistance, which leads to the electrical voltage being changed to heat. If you have access to a DMM, whats the voltage at the amp's power terminals?
Old Jun 4, 2005
ex_03's Avatar
Godlike member
O.k. thanks for bringing it! and the first thing is you should take right back to the shop who installed it installs are usually under warranty for one year some longer, But do it fast and be like what the hell man my car is ruined becuase your guy's install!...If they say"to bad" then threaten to sue!
Old Jun 4, 2005
SpecialEdCivic's Avatar
SpecialEdCivic is an unknown quantity at this point
Is the amp ohmage and the sub ohmage matched correctly?
Old Jun 4, 2005
LudlamTheory's Avatar
i boogie for the raindrops
it takes a ridiculous amount of current to do things like that to a 10 inch run of 4 gauge.
what amp are you using?
Old Jun 4, 2005
Another thought.. I don't think this would cause that much current but is your gain at the correct position for the voltage of your preouts?
Old Jun 4, 2005
im just goin to take it back to the shop cause i dont know what is wrong and i cant really explain cuase i dont know that much
Old Jun 4, 2005
thats your safest bet, im curious what caused it
Old Jun 5, 2005
me too i messed with the gain a little bit and that seemed to make the ground not heat up anymore but it wasnt really doing any differnece when i was turning it up and down so i dont know if the amp is just had it r what im confused. but o well ill be taken it in here soon when i get free time
Old Jun 5, 2005
ex_03's Avatar
Godlike member
The amp still works? What is it?
Old Jun 6, 2005
i took it in today and they said taht it was one of two things
1. the ground is not grounding properly so it has to much resistants so they grounded it more
2. they amp was sucking up to much power so it was low voltage goin to the amp and causing it to do that
but who knows it seems to be ok for now
Old Jun 6, 2005
ex_03's Avatar
Godlike member
I would say the ground was loose, becuase like luddy said it takes alot power to just melt 4guage!
Old Jun 8, 2005
amp still works yes
and its a crossfire vr602
Old Jun 8, 2005
turboslug's Avatar
Super Hoser
turboslug will become famous soon enoughturboslug will become famous soon enough
hmm...if ground was loose, wont there be a lot of sparks, and the constant sparking would cause a lot of heat?
maybe that's why it melted?
Old Jun 8, 2005
ex_03's Avatar
Godlike member
Originally Posted by Supermanrider
amp still works yes
Thats why, When I installed for a shop we would send them back to crossfire but in order to get a credit it would have to be blown, we tried to plug them in to 115v wall socket and they would still work, until we plugged the 115v into the speaker output side of the amp. They are pretty well built amps.
Old Jun 8, 2005
chaoticmav's Avatar
chaoticmav should not be trustedchaoticmav should not be trustedchaoticmav should not be trustedchaoticmav should not be trusted
NEVER threaten to sue, EVER, if you do 9/10 time they will say, "At this time I will have to end out conversation" you SCREW yourself over by threatening that, especially if u don't 100% intend to. Always ask to talk to a manager, go higher till u get what you want.
Tedverseti
Apr 23, 2020 01:45 PM
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Munzy
21
Oct 7, 2015 07:48 AM
Tedverseti
Sep 29, 2015 05:41 PM
260000milesgoal
Sep 25, 2015 07:41 PM
