Keyless entry question.
I'm unusually bored.
I dont have keyless entry on my lx, but it's always bothered me a little. How hard would it be to get this option? I have power door locks. Someone told me this is an added feature on most car alarms (I've never had one), so do I need to get an alarm installed, or is there an easier set up? I searched some, and didn't really find anything, but I know some super-smart-about-civics people could help me here. Thanks
You can get an aftermarket system keyless entry system installed for anywhere around $150-$250.. depending on how many bells and whistles you want.. but you're better off getting a car alarm/remote start/keyless entry.. you can pick one of those up for around $300-$800 installed.. again depending on how many options, 1 or 2 way, etc etc..
I have an alarm, i think i paid somewhere around the 250 to 300 range for it, its a clifford alarm, its not on my civic but its on my other car which didn't have a keyless entry but did have power locks. It has remote start on it as well. Can't go wrong with it, you get your keyless with added security.
http://www.handa-accessories.com/civelec01.html
For 120 bucks you can get the keyless entry that the factory intended.
You could spend $120 for it or $200 on an alarm/keyless entry. Not to say jb1004 is wrong, you could get that but the factory alarm isn't that great of an alarm. Its up to you though.
wait he already has power door locks right? so he just go on ebay and get a remote for like 20 bucks or whatever they go for now, and program that to his car? isnt that the cheapest and easiest?
Hey I found a keyless entry kit at pep boys for 40 bucks, and with the wire color chart in the diy section, it was a relatively easy hook up. Took less than an hour including clean up time. Im pretty damn handy, though. I would have done this a long time ago if I knew I could do it without too much trouble. I got all of you beat on price, too...lol and amazingly enough, it works. Thanks again.
The kit is made by bulldog and came with two transmitters... just said "remote keyless entry" on it...I found it in the section of pep boys that had all of their amp wiring kits and such. Finding the correct wires under the kick panel is the hardest part, that and then making the splices. Also, you need a power source, so I used the 12v constant from my stereo wiring harness. Then I just screwed the little box to the kick panel itself. Let me know if you need other help.
i boogie for the raindrops
go around and find some shop with the prestige special...
shop around here does 79.99 for a simple prestige shock sensor and keyless installed
lifetime warranty too
im sure some shop around there does the simple alarm for cheap
hint: go to the "bad neighborhood"
h4ldol
Apr 24, 2017 08:16 PM
Ziggy1999
Oct 15, 2015 07:56 PM
IronFist
Sep 25, 2015 07:13 PM
pilebuck13
Sep 21, 2015 10:45 PM
There is gl@ss in my @SS...
