taking off front console... how the hell?
Old May 8, 2005
skizlano's Avatar
skizlano is an unknown quantity at this point
im trying to take off the upper panel and just can't without what seems like something thatll screw up my dash.
btw, im trying to do this http://www.ben-johnson.org/blog/index.php?p=37 and take out my hu.
any help on how to get to the clips and how to remove the panel?
Old May 8, 2005
dirtySAMURAI's Avatar
I log in from time to time
what's the "upper panel?" the cigarette lighter portion?
Old May 8, 2005
oh. the headunit part. i just pulled from inside the dash. it's hard to explain, but you know the two screws you take out from the bottom? well, further in the dash there is an absolute end to the metal that holds the headunit in place. just pull on that real hard and the thing should pop out. if that doesn't work, then it'll probably break...so don't listen to what i say
Old May 8, 2005
skizlano's Avatar
so you didnt pry from these points only?
http://www.ben-johnson.org/blog-imag...-annotated.jpg
Old May 8, 2005
skizlano's Avatar
the only thing i can figure to use is a screwdriver to lift the edges up a bit, but pulling to hard in one point impresses the dash in and it looks pretty ****ed up.
where 'inside the dash' did you pull from?
Old May 8, 2005
ajhdragon's Avatar
7thgens official a$$hole
when you take the screw out from the botom try takeing out your guage bezel and dropping the glove box and get your hands in there and push from behind, and all the metal and crap that holds the head unit in place.
Old May 8, 2005
Rennen's Avatar
New Mod on the Block
are you trying to remove the trim peice that contains the headunit, a/c controls, defroster, etc.?
Old May 8, 2005
Rennen's Avatar
go here Click This!!!
Old May 8, 2005
skizlano's Avatar
so taking that off will let me put my hand behind it from below it and push out? thanks for the link
Old May 8, 2005
skizlano's Avatar
shat. mine is 01.
Old May 8, 2005
Rennen's Avatar
same concept.
Old May 8, 2005
skizlano's Avatar
yeah, and i tried this: http://www.7thgencivic.com/forums/sh...d.php?t=153830
but the problem i have now is that those two screws on the metal frame beneath the HU are set in there well. my screwdriver doesnt even get a grip on them.
Old May 8, 2005
binky's Avatar
binky is an unknown quantity at this point
that guy did a crappy job, didn't finish the hole off very nice and just leaves the wire exposed; doesn't look clean at all.
Old May 8, 2005
you have to use a 10mm socket wrench to get the bolts out
Old May 8, 2005
Rennen's Avatar
^yeah. its better to use a socket wrench than a screw driver.
Old May 8, 2005
skizlano's Avatar
wonderful. i just put everything back together b/c it's getting dark and i don't have a garage. guess ill hit it up early tomorrow
Old May 8, 2005
MegaHurtz's Avatar
Read the sticky next time
This should help you out
http://www.7thgencivic.com/forums/sh...d.php?t=176750
Old May 8, 2005
diskreet's Avatar
you absolutly must get those screws off. but agreed on the stickie
Old May 8, 2005
Caucasian.Asian's Avatar
pull as hard as you can on the console. the screws will loosen up, and eventually fall out.
Old May 9, 2005
coop's Avatar
coop is a jewel in the roughcoop is a jewel in the roughcoop is a jewel in the rough
yep, gotta use a socket the first time you undo it. Use a screwdriver next time though incase you need to get in there again. Wrap a flat head screwdriver with some tape and *gently* pry around the center console, and it will come loose. IF you brute force it you'll probably loose several of the clips that help hold it in.
Old May 9, 2005
PopcornPlaya's Avatar
Electric Boogaloo...
Mine don't even have phillips or hex, or flat slots in them for a screw driver. Make your job easier and use a socket.
As for the DIY, the one that's linked (to my knowledge written by Megahurtz) is for an 04+
There is also one on here for an 01 located heredon't know if it's any different, but anyway)
The crutchfield Mastersheet is on here somewhere too.
Old May 9, 2005
skizlano's Avatar
yeah, i was getting the 04 one down and all and then headed out to my car to find it wouldnt work. i found that 01 which helped out. thanks all for the advice.
Old May 9, 2005
WhiteRabbit's Avatar
when you do get it all off, I'd recommend you run the wires from around back of the console. you can always tuck the wires up behind your center console. out of sight, out of mind. But if you drill that hole, you have to live with that hole. forever. Or pay for a new panel, and why have needless expenses?
I say save your self the drill time and just drop the wires down from around the back of the dash (when you finally do get the radio out)
Old May 10, 2005
MegaHurtz's Avatar
8mm
Old May 10, 2005
you metric bastards lied to me!
Old May 16, 2005
hatE's Avatar
hatE is an unknown quantity at this point
i took out my center console the other day .. yeh its basically those 2 screws which is a 10mm size .. then after u take those out .. rite above the metal where the 2 screws were.. u can feel the console .. push that part and u shud notice that the bottom of the console tends to move a lil bit .. if u push hard enuff.. it will push the bottom of the console enuff to get a flathead under .. on the pic where the arrows are .. there are tabs.. i just slowly eased my flat head along the whole console.. u'll notice the clips beginning to pop out.. once u pop all of them off.. then done.. it shud just come straight out .. be careful with the flat head tho .. wrap it with somethin if u have to so it won't fucc up ur **** .. i did it in like 5 min
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
crowtoo
May 11, 2015 06:50 PM
Jigee
May 9, 2015 11:18 AM
GH04si
Apr 15, 2015 08:13 PM
ImmortalEX
Oct 31, 2001 10:00 PM
