stock HU problem
Old May 16, 2005
Jaykuai's Avatar
ish...
stock HU problem
i removed the CDA-9835 and right away in that same moment installed the stock HU..
dead.. no signal of life..
is there any way i can give current to it so i can see if the HU is dead or is a car problem?
Old May 16, 2005
iluvmycsx
Guest
Posts: n/a
i am assuming that you discontected your battery when intall it if not i would check the fuses you might have blown a fuse
also i believe that you have to have the stock deck security code it should of came with the owners manual i believe it a 4 number code
Old May 16, 2005
TiM3's Avatar
TiM3 is an unknown quantity at this point
My security code was 5 numbers.
Old May 16, 2005
iluvmycsx
Guest
Posts: n/a
wasnt sure if it was 4 or 5
Old May 16, 2005
Jaykuai's Avatar
ish...
yes i got the card, but the stereo wont turn on.. so.. how can i enter it..
i will check the fuses, thanks!
any particular one that i should check, or just go crazy and check all ?
Old May 16, 2005
iluvmycsx
Guest
Posts: n/a
check all fuses
as for the code hit power button then enter the 5 digit code then you should have power
the stock deck should light up but wont work try putting a cd in and trying to eject it
Old May 16, 2005
Jaykuai's Avatar
ish...
bah.. the cd doesnt even work, that was why i changed it in the first place hehehe..
Old May 16, 2005
NewCivicGuy's Avatar
NewCivicGuy is an unknown quantity at this point
I would try to find the code first. If that doesn't work, call your local dealer and b**ch up a storm about them not giving you a code.
Worked like a charm for me...
Old May 16, 2005
CraigW's Avatar
I think it is a power problem, could be constant or switched power that is missing, Also possible missing ground.
The radio code for my car is on a white sticker in the glovebox, (real security)
Old May 16, 2005
Jaykuai's Avatar
ish...
the problem was a fuse..
Thanks! Radio working now..
that was a rush... the civic is sold hehehe..
Old May 16, 2005
iluvmycsx
Guest
Posts: n/a
good to hear
crowtoo
May 11, 2015 06:50 PM
cloudguy
Apr 28, 2015 05:02 AM
kanin247
Bolt-on Engine Performance
Apr 25, 2015 05:44 AM
