Amp Install On Sedan
guys,
im almost done w/ my amp install, only one problem i dont know how to route my power wire, i can see the hole in the firewall from the engine bay but how do i access it inside?
is there an existing hole thats easy to use or should i make one?
thanx
thanx
well, i ran mine down the passenger side, seeing how that's the side that the battery is on. i consulted a car audio place nearby my house, and they run it through the driver's side, but then we'd have to drill (and i don't like to drill). so mine goes down the passenger side. well, if you look down along the firewall behind the air resonator (if you have a stock intake), you will see a grommet that has a lot of wires running through it. i poked a hole in there using a screwdriver, and ran it through there. to access it on the inside, you take off the kick plate that is under the glove box, and pull back the carpeting.
jru27
Jun 19, 2015 03:51 PM
