tweeters
Old May 3, 2005
05reverb's Avatar
05reverb is an unknown quantity at this point
tweeters
My buddy wants me to install his new HU. I installed alot of sound systems, but never with tweeters. I was wondering where you hook it up? Do you have to run the front out RCA's from the HU to a 4 chanel amp, then hook up your 2 front speakers to 2 chanels then your 2 tweeters to the 2 other chanels? also I ordered my 2005 reverb and it comes with tweeters, and i want to change my HU so where will i have to hook up the tweeters?
Thanks
Old May 3, 2005
phydo's Avatar
phydo is an unknown quantity at this point
This is where I put mine. complete with swivel mounts
Old May 3, 2005
phydo's Avatar
Also, in regards to wiring, you need to get a crossover. most component systems come with them. you run the speaker wires into it, and it separates the high and low freq's, then has outputs for the tweeter and the woofer.
Old May 3, 2005
05reverb's Avatar
but I don't think my buddy had a crossover. the tweeters were hooked up on his old deck, but it got stolen, now he wants me to install his new one this friday. I think he had it on a 4 chanel amp, i'm not sure because I never saw his system that much, but he said he had his sub and speakers in the amp. could it be that he had the tweeters on 2 chanels and that he bridged the other 2 chanels together for the sub?
Old May 3, 2005
05reverb's Avatar
i don't think he had the whole component set-up, he probably only had coaxial speakers in the front and back, and those 2 tweeters
Old May 3, 2005
phydo's Avatar
See, the problem is, the tweeters can only handle frequencies above, lets say, 3k hz. now, if you connect them just to the amp, they'll get all that bass and mid-range that they don't want, and blow. you gotta make sure that however you have it set up, you can set a high pass filter (HPF) on the tweeters so that way they only get the high noises, and you wanna do a Low-pass filter on the woofers, so that way they don't get the highs.
Old May 3, 2005
05reverb's Avatar
thanks, thats exactly what i was looking for
Old May 3, 2005
booba5185's Avatar
7thgen Terminator Ninja
booba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to behold
yup i forgot about about that once and my tweets started to smoke hehe
Old May 4, 2005
05reverb's Avatar
so how are the tweeters in the reverb set-up? is there a crossover somwhere or does the stock HU send out 2 additional chanels with only the high frequencies + the 4 chanels for the door chanels? I'm getting my reverb in 3 weeks and want to put in a aftermarket HU
Old May 4, 2005
evilone's Avatar
The Nightraid crew - Sensible Ownage
evilone is a jewel in the roughevilone is a jewel in the roughevilone is a jewel in the roughevilone is a jewel in the rough
Tell ya what....I've been looking for a reason to break out the soldering iron lately. Find the specs for the frequency ranges, I'll build custom crossovers for them, and I'll sell 'em to ya for cost....this way it's tuned for you, you get them cheap, I get to play, and I'm not losing money. How's that sound?
Old May 4, 2005
05reverb's Avatar
sorry, but I only want to know how the tweeters in the reverb are hooked up. I'm curious to know what sends out the high frequencies to the tweeters in the reverb (the HU or a crossover). Thanks Anyways! Maybe when I get my car in 3 weeks, i'll let you know again.
Old May 4, 2005
evilone's Avatar
If I had to guess, I'd say probably a built-in crossover in the HU. Not really sure, but that's how they were hooked up in my friend's Jetta, it had stock tweeters in the doors, and he had to leave them unhooked because he didn't have an external crossover.
Old Jun 22, 2005
jay47's Avatar
jay47 is an unknown quantity at this point
So, I ordered a new cd player just 3 days ago, and it does not have a crossover, but I have factory components in the front, will I have to buy a crossover?
Old Jun 22, 2005
on my 02 sedan, I ran the four speakers off a separate amp. Then bought new tweeters with built-in crossover and wired them to the pioneer deck power. More than enough power to hear them.
Old Jun 22, 2005
Factory components? That doesn't make sense. Anyway, I know aftermarket component speakers come with a crossover, which is required or you'll blow the speakers. I have a crossover on my deck but its not really necessary. You need one with the components tho.
Old Jun 22, 2005
draganjr's Avatar
draganjr is an unknown quantity at this point
gearbox, i have a question regarding this info on tweeters and etc. I have all pioneer stuff, mids and highs. I have 3 ways in the front and 4 ways in the rear.
the tweeters i have are pioneer too. right now the tweeters are hooked into the front speakers, not on a crossover or on the hu but the front speaker wires. Is this ok?
Old Jun 22, 2005
Mystic3030's Avatar
Yup, i'm an A$$hole.
The OEM tweeters have a bassblocking capacitor inline in the wiring to keep the low end frequencies from getting to them, it has nothing to do with the HU, and the wires are isolated so the wiring harness behind the HU does not have any extra wires for the tweeters.
Old Jun 22, 2005
that doesn't sound right. It messes up the ohm load (which could ruin the deck), and there's no crossover unless you have something set on your deck. Very bad for tweeters.
Old Jun 22, 2005
draganjr's Avatar
so is there an aftermarket crossover i can place in there for the tweeters and the speakers?
Old Jun 22, 2005
i have a feeling the tweeters have a separate crossover or they would be ruined by now. Its like a small box or something attached to the wires. The regular speakers don't really need a crossover; I have mine set to 50Hz so it plays a little bass. It won't blow them or anything. But if you have a sub, then set it higher maybe around 80Hz.
Old Jun 22, 2005
booba5185's Avatar
gearbos, where did u put ur cross overs? i put mine in the door, but i don't like it there, any ideas?
Old Jun 22, 2005
they're in the door, but mine are small enough to just stuff in there. Its like a small pack of gum size.
Old Jun 22, 2005
draganjr's Avatar
The tweeters have a little box thingy on it, i guess it is the crossovers!
i had this tweeters with this setup in a different car for about 2 years and now in this car for about two years!
I just ordered some SPS-171A for $100! Gearbox where are your tweeters located?
Old Jun 22, 2005
MegaHurtz's Avatar
draganjr, pm me, I have a nice little set of MB Quart crossovers that you might be interested in,I will let them go cheap
Old Jun 22, 2005
Old Jun 22, 2005
booba5185's Avatar
Originally Posted by gearbox
repost in the same thread....hahahahahahahaha
Old Jun 22, 2005
draganjr's Avatar
gearbox is your crossovers inside of the door or the outside, if you know what i mean.
Old Jun 22, 2005
its inside the door panel between the outside plastic and metal. So if you take the door panel off, you can see the bundle of wires and the x-over.
ZoSoIV
Sep 17, 2015 07:17 PM
Jeffdp
Aug 5, 2015 11:38 AM
STang57
Aug 2, 2002 07:59 PM
TroyA
Jul 7, 2002 10:18 PM
