Installing front speakers on a car with manual windows
Old Jun 21, 2005
brian_tr's Avatar
brian_tr is an unknown quantity at this point
I've looked at the DIY about installing front speakers cept that DIY was for models that had power windows...problem is i don't have power windows and when i went to try it i got stuck where the window crank goes through the door panel
anybody know how to get past this problem?
any help would be much appreciated
thanks
-brian
Old Jun 21, 2005
CraigW's Avatar
There should be a retainer clip shaped similar to a U or an Ohm symbol behind the crank handle on the shaft. If you push in on the panel around the crank you should be able to see it. Find a way to grab the clip and remove it from the shaft and the crank handle will slide right off.
Old Jun 21, 2005
booba5185's Avatar
7thgen Terminator Ninja
booba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to behold
there's a little "C" clip in between the crank and the plastic spacer on the door, it's not fun to get off, they have tools for it at napa, but it pushes through...lemme see if i can find a pic for ya
Old Jun 21, 2005
LayinLo's Avatar
LayinLo is an unknown quantity at this point
needle nose pliers, man
Old Jun 21, 2005
booba5185's Avatar
i used a right angle for wood working hehe
Old Jun 22, 2005
paradoxblue's Avatar
crowshay(sp) hooks..t he small mettle ones work great
Old Jun 22, 2005
skipbarber's Avatar
look at the door locks DIY. that shows you what everyone here is talking about.
Old Jun 22, 2005
dragon1981's Avatar
dragon1981 is an unknown quantity at this point
What I did since I didn't have the pick or pliers was the sock method when I first did my doors with speakers. Get a sock that you don't need because you won't be wearing it ever again. Then get the sock under the ring from underneath and then just see-saw it back and forth until you feel it catch. When it pops out be sure you are not near any drains or near any place where it will get lost easily. When your not rich and don't have the tools you have to learn to improvise.
Old Jun 22, 2005
BassKadett's Avatar
BassKadett is a name known to allBassKadett is a name known to allBassKadett is a name known to allBassKadett is a name known to allBassKadett is a name known to allBassKadett is a name known to allBassKadett is a name known to all
I used one of my girl's hair pin things. Bent it all up and worked that bastard loose.
Old Jun 22, 2005
brian_tr's Avatar
thanks you guys have been a great help
i actually used a paper cilp that i bent into a hook and grabbed an end of it
had a hell of a time putting it back in..i'm still not sure what i did but i ran out of time so i only managed to get the driver side speakers in
thanks for all your help once again.
Old Jun 22, 2005
chicohonda02's Avatar
Since 2002 Baby!
awww what a noob, I was once there, but I've been founf for quite a while. LOL
Old Jun 22, 2005
booba5185's Avatar
you clip it on the crank and then push the crank on, it's easy to put back on
Old Jun 23, 2005
dragon1981's Avatar
He's right but if you need any more help, feel free to ask. Did your panel secure all the way down?
Old Jun 23, 2005
Kyle23's Avatar
Kyle23 should not be trustedKyle23 should not be trusted
they also make a tool 4 this...
Old Jun 23, 2005
dragon1981's Avatar
Do you have a panel popper?
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
mistermenphis22
Apr 3, 2016 08:06 AM
bsmiley
Apr 27, 2015 01:27 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
JeffSpeed21
Nov 3, 2001 10:32 AM
