Disabling Alarm
Old May 2, 2005
Treellama's Avatar
Treellama is an unknown quantity at this point
Disabling Alarm
Hi,
Last summer I had a viper alarm installed in my 2001 lx, and it works great. One really irritating thing, however, is that when I go to reconnect my battery, the alarm goes off until I hit the kill switch. Now I understand the reasoning behind this, but there's got to be some way around it, because I assume that when you take your car to the shop, they're not setting off the alarm everytime they need to disconnect the battery.
I just moved, so I have no idea where my manual is, and I doubt it would be useful anyway. Anyway, help would be appreciated.
PS, I'm not looking to disable override the ignition-disable or anything sketchy. I just want to remain on friendly terms with my new neighbors.
Old May 2, 2005
Taffy's Avatar
Taffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant future
Set the alarm to Valet Mode. Turn key to ON position but do not start the car. Then turn the key to the OFF position. Then within 10 seconds find the Valet/Program button and hold it down for more than 3 Seconds. The Alarm will chirp and the LED light will stay lit up. VOILA! Valet Mode!
Old May 2, 2005
Treellama's Avatar
Does valet mode work after the battery has been disconnected? What about the fuse coming from the battery to the alarm? If I pull that and reconnect the battery, will the horn sound? Will the car start (I assume not)?
Old May 3, 2005
Taffy's Avatar
If you pull the fuse that goes to the battery, it will still go off once you reconnect the fuse. But if you switch it into Valet Mode it will still remain in Valet Mode if you disconnect the battery and reconnect it.
solarpunk70
Apr 12, 2016 11:43 AM
frank_kleng
Sep 29, 2015 10:55 PM
MamaBear2015
Sep 24, 2015 11:34 AM
meicalnissyen
Sep 22, 2015 06:20 PM
First Car
Sep 8, 2015 08:54 PM
