Whiny noise
Old May 2, 2005
dru106's Avatar
ThE CoRRupToR
Whiny noise
Im gettin the whiny interference in my stereo system after installing my new alpine amp. This ony happens when i get home. What can be the cause? They said it might be a bad ground and i tried using a wire and touchin a better ground but still no luck. I have the pos+, 3 RCA cables, and remote runnin all on the same side...... someone told me that i should run the remote seperate from the other cables??
Old May 2, 2005
LiKEaFeRiO's Avatar
Are you running the power cable from the battery to the trunk on the same side as the RCAs and/or speaker wires?
If so, that may be the cause.
Old May 5, 2005
Blk2k2civy's Avatar
Blk2k2civy is an unknown quantity at this point
check to see if your RCAs could off be pinched when you put back your panels could be touching gnd
nirvanaguy
25
Oct 26, 2017 07:26 PM
fvckbg
Sep 8, 2015 09:55 PM
Josh 1973
Sep 7, 2015 10:10 AM
junkyardguy
20
Sep 6, 2015 10:07 PM
tommycanada
Sep 5, 2015 04:59 PM
