Need help w/ 0ga. wire
Old Apr 28, 2005
02SILVEREX's Avatar
02SILVEREX has a little shameless behaviour in the past
Exclamation Need help w/ 0ga. wire
I am getting ready to instal my system. I have rough plans for the install, and all of my components are in, so is the hardware.... But I need help trying to run the 0ga. wire.... Just wanted to throw it out there, get some opinions. Have any of you run a 0ga. from the batt to the trunk? If so, how did you get it through the firewall? I have no problem drilling a hole.... But if anyone has a better solution.... I was thinking about running it under the car... I don't know about that though.... anyway. Just wanted your opinions. Thank you in advance, as I know this will bring a lot of debate...
P.S. No I won't tell you what's going in. I know you'll all at me for it. Oh well, you'll just have to wait until it's done.
Old Apr 28, 2005
eye_see_you's Avatar
let the devil out
through a grommet in the firewall is most peoples choice otherwise you can drill and make your own
under the car is a bad idea IMO because of my exhaust and haveing to support it etc so much
Old Apr 28, 2005
02SILVEREX's Avatar
I can understand the under the car thing. I was just puting it out there, because thats what some others have said. As far as putting it through a grommet... I haven't found one thats sutable for 0ga.. I am trying to find those that have run it their vic, to see how the've done it.... Or where the've done it....
Old Apr 28, 2005
let the devil out
i've run 0 ga through my passenger side firewall cannot remember what it was supposed to be and i'm talking about my 02 sedan too. looks like you may have to drill
Old Apr 28, 2005
Falcon's Avatar
Falcon is an unknown quantity at this point
i think you might have to drill.. i drilled for a 4ga wire (but just because i gave up looking for grommets)
definately do not run it under the car
also, keep it far far far away from ANY audio components, that is a very large wire, and will produce quite the magnetic field
incidently, what on earth do you need a 0ga for, or is it just for looks?
Old Apr 28, 2005
GTOnizuka's Avatar
GTOnizuka is an unknown quantity at this point
ya i went through the passenger side, but it was really hard to get to. i used like two separate 14 or 16ga, which is a lot smaller so you may need to drill, which would be though also =[
Old Apr 28, 2005
drummerboy990's Avatar
drummerboy990 is an unknown quantity at this point
I ran mine through the drivers side through custom grommets. Heres some pictures to get an idea:
Pic 1
Pic 2
Pic 3
As you can see its run in the drivers side and down the center of the car. I thought there might be a bump in the carpet or something but it actually sits really flat. Not noticeable at all.
Old Apr 28, 2005
MegaHurtz's Avatar
where did you drill that hole?
Old Apr 28, 2005
cosmo's Avatar
cosmo is an unknown quantity at this point
I ran 4ga. throught the same gromet as the main wiring harness without any modification.
Old Apr 28, 2005
ex_03's Avatar
Godlike member
ex_03 is on a distinguished road
ran mine under the car never had a problem never had to drill. There is a gromet in the trunk right where the seats fold down on the drivers side, I'll try to get pics of it.
Old Apr 28, 2005
MegaHurtz's Avatar
I am running my 0 gauge soon too so this is good informations for me
already got the wire sitting on the bench downstairs
Old Apr 28, 2005
AlpineCivic's Avatar
"drummerboy990" made that hole through the drivers side firewall. Thats where the clutch master cylinder goes if the car is stick.
I ran my through the passenger side firewall through the main harness groumet just like "cosmo" did. I first ran an 8 gauge wire, then a 4 gauge, then finally my 1/0 gauge wire.
Old Apr 28, 2005
MegaHurtz's Avatar
well I already ahve the 4 thru so next comes the 0
how did you get it through? I am thinking run it through as my 4ga is coming out and just tape it to the end and pull em thru
SimpleUser
Apr 24, 2021 02:54 AM
Kevinsisco
Aug 31, 2015 12:04 AM
sch2cm
Jul 21, 2015 09:58 PM
CivicsClass101
Jul 9, 2015 11:14 AM
robbie374
Jul 7, 2015 02:56 AM
