Wiring sound right?
Old Apr 16, 2005
Seabass's Avatar
Seabass is an unknown quantity at this point
Wiring sound right?
Hey everyone, ok i have 2 15" fosgate punch hx2s, I was wondering if these calculations are right, im trying to tune it to 37hz and the box is 4.15sqrfeet(inlcuding all displacements), and it says to make the port 3.04inches long. That does not sound right at all...btw its in 1 big box not dual chamber. Thanks everyone.
Old Apr 16, 2005
ex_03's Avatar
Godlike member
ex_03 is on a distinguished road
where did you get demensions from? one big box= coupled enclosure, which is never reccomended but will probably be ok.what voice coil are they, Model number would be good.mo info.K I just checked web site say's 4X8" one port per sub @4.0 cubic foot.here be the link, that means your total volume after displacement should be 8 cubic foot. Sealed would be a better route for space.
http://www.rockfordfosgate.com/scrip...ted=1050098189
Old Apr 16, 2005
MegaHurtz's Avatar
what about the wiring?
Old Apr 16, 2005
ex_03's Avatar
Godlike member
ps. thats for the small vented too!
the large is 5 cubic ft. with 4 4"X18" ports which I have built for some old zues 18"s and had sick low bass but let me ask you are you going for spl? or just sick bass?
Old Apr 17, 2005
Seabass's Avatar
rfd2115, and 4cft is max volume for sealed enclosure, look at the ported volume, minnimum of 2cft, I have 4.1(actually its like 4.3) which is about the right size(plus i added a good amount of polyfill)
Old Apr 17, 2005
ex_03's Avatar
Godlike member
excactly per sub!
Old Apr 18, 2005
Seabass's Avatar
excactly per sub!
yeh....2cft per sub=4cft, thats what i got.
Old Apr 18, 2005
ex_03's Avatar
Godlike member
Yea dude that should be sick.let us know how it turns out!
Old Apr 19, 2005
Seabass's Avatar
anyone know how long the port is supposed to be? Thanks.
Old Apr 19, 2005
ex_03's Avatar
Godlike member
4" diameter and 8" long, be sure to round the edges at both ends. A hand router is good for this if not a rounded file.
Old Apr 19, 2005
Seabass's Avatar
But when i used a port calculator it said 3inches, 4" by8" is if you have the box at that volume, whereas mine is 4cft.....
Old Apr 19, 2005
ex_03's Avatar
Godlike member
Yea you cant always use port calcs when you change things up, but if you look at rockfords sheet on there site from my link above it shows that 4" X 8" is the port you'll use for 2cubic ft. to 4 cubic ft. enclosure per sub, so if you have a 4ft. total enclosure volume, you will need 1 4" X 8" port per sub, so in your case two ports for the box.You may want to try using polyfil or bags of cotton from a fabric store. It will help give your subs a smooth roll off. about 2 pounds per sub.
Wild Cranker
427
Jan 28, 2016 06:49 PM
danace99
23
Jun 28, 2015 08:49 AM
TiggerDX
Jun 18, 2015 01:43 PM
Black91civic
Jun 6, 2015 08:15 AM
MamaBear2015
May 3, 2015 02:17 PM
