'04 Headunit Wireing? info..?
Old Mar 20, 2005
paradoxblue's Avatar
im about to pull out the head iunit. i dont have a wireing kit for it.. will this kill me for replacing. do i NEEd one?
since most of the wires for speakers and power will be re run. i will be needing the 12vdc that runs to the ignition, and the rear speakers.
aside form that and the antenna its all being re run. will i be ok to do this?
i looked over the site but was not able to find a wire guide on the inside of that console..
anyone know a colour code chart?
thanks!!
Old Mar 20, 2005
CraigW's Avatar
I recently did my 05 the Metra harness, # 70-1721 is the correct one. (dont cut the factory wires)
www.metraonline.com
I used a Metra 99-7899 mounting kit, going to have to go back and do some more work. (rattle on HU and cage and poor fit on kit) it looks o.k.
Check out the DIYs and and headunit post here, there is a lot of info. It can be a little tricky the first time on these.
Old Mar 20, 2005
well im more or less planning to chop the stock. cause im not using most of it. and dont have the cash for wireing harness
im trying to wire in as much as i can as cheap as i can.
also im not new to electornics. splicing into the stock is quite easy for me
im just trying to figur eout. what is what.
Old Mar 20, 2005
TemjinX2's Avatar
isn't a harness like $20? might as well keep it a clean. its your headunit so up to you i guess.
Old Mar 20, 2005
yeah they are. which wll cost me around 40cdn or more by the time i have it :|
and i have wire splis. i only need to spline into like 8 wires. i wont be lopping off the stock connector
Old Mar 20, 2005
PopcornPlaya's Avatar
Electric Boogaloo...
You're wanting a wiring schematic no? J187(I believe) posted one somewhere on here. Search for posts made by him and you should find it.
EDIT: Found a few thread for ya...
http://www.7thgencivic.com/forums/sh...ring+schematic
Old Mar 20, 2005
Or this (It's for an 03, but should be identical)
http://www.7thgencivic.com/wiring/pr...web_task=print
Search man.
Oh, and don't forget to rep me.
Old Mar 20, 2005
popcornt hanks a bunch man. that site had exactly wut i needed
Old Mar 20, 2005
phuviano's Avatar
Slowest 7thgen in the GTA
$40 cdn??? where u shop? I bought my wiring harness for $20 bucks. They do range from $20-$25 in stores though. I would just use a wiring harness, but like it was said before "its your car".
Old Mar 20, 2005
yeha no wher elocal. and i have wire splicers. so i just splice in and bam
SimpleUser
Apr 24, 2021 02:54 AM
Kevinsisco
Aug 31, 2015 12:04 AM
sch2cm
Jul 21, 2015 09:58 PM
CivicsClass101
Jul 9, 2015 11:14 AM
robbie374
Jul 7, 2015 02:56 AM
