Wiring Diagram
Old Mar 13, 2005
4Saris's Avatar
4Saris is an unknown quantity at this point
Wiring Diagram
Anyone know where to find the wiring schematic for a 2003 Expedition? The Nav system calls for me to tap in to the speed sensor wire (I think its a gray/black wire) and I also have to tap into the reverse lamps. Thanks!
Old Mar 13, 2005
Blahman2's Avatar
One Slow Civic.... But I can take turns pretty well :-)
Blahman2 should not be trustedBlahman2 should not be trustedBlahman2 should not be trustedBlahman2 should not be trusted
locating the speed sensor shouldn't be too hard. Well, that is if you know what a speed sensor looks like. But, maybe you'd have better luck posting on a ford forum. Not sure if us honda guys can help that much.
Old Mar 13, 2005
ex_03's Avatar
Godlike member
ex_03 is on a distinguished road
www.directechs.com but someone in here will have to give you there screename and password. or print it for you. I dont install professionally anymore therefore have no access!.
Old Mar 13, 2005
profuse007's Avatar
Senior Member
profuse007 is an unknown quantity at this point
Speed Sense GRAY/BLACK (AC) @ PCM OR WIPER MOTER
Old Mar 13, 2005
Blahman2's Avatar
Whoa! I want a pass to that site!
Old Mar 13, 2005
4Saris's Avatar
Yeah, I've tried that. I remember someone being on here that has a logon to a website that allows you to lookup any vehicle. We used to have linked to this site as a matter of fact without having to logon.
Old Mar 13, 2005
ex_03's Avatar
Godlike member
gve me a couple days ill get it!
Old Mar 13, 2005
thoughthard's Avatar
thoughthard is an unknown quantity at this point
Sorry about the caps. Too lazy to type it out.
PCM - THE POWERTRAIN CONTROL MODULE IS LOCATED ON THE PASSENGER SIDE FIREWALL. THE VSS WIRE IS IN THE PLUG CLOSEST TO THE FENDER, PIN 13
Reverse Lights BLACK/PINK (+ polarity) DRIVER KICK PANEL, HARNESS TO REAR
Old Mar 14, 2005
4Saris's Avatar
Yeah boy! Thanks for the information, time to get to work now!
Old Mar 14, 2005
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
Let me know if you have anymore problems, I'll print the whole wiring scheme
Old Mar 14, 2005
ex_03's Avatar
Godlike member
You guys aren't going to believe this but, I went back to www.directechs.com and typed 123456 as the password and it worked!!!
Enjoy all...
Be sure to rep me.
Old Mar 14, 2005
J187's Avatar
hahahahaha. Nice work.
*Spaceballs*
1-2-3-4-5 That's the combination an idiot would have on his luggage!
Old Mar 14, 2005
ex_03's Avatar
Godlike member
*Spaceballs*
yea I tried that first, only becuase I knew that there passwords are 6 digits long.Too funny
Old Mar 14, 2005
profuse007's Avatar
Senior Member
great find
Old Mar 14, 2005
PopcornPlaya's Avatar
Electric Boogaloo...
www.the12volt.com will have the diagram, I just don't feel like searching for it.
Old Mar 15, 2005
darklegacy540's Avatar
darklegacy540 is on a distinguished road
When you use that site, be sure to double check your wires with a DMM.. we use that site at work and there's been several occassions when the wires were wrong.
juror
Suspension DIY
Jul 30, 2019 03:28 AM
rman1900
21
Sep 10, 2018 04:52 PM
sch2cm
Jul 21, 2015 09:58 PM
Bounddyy
19
Jul 20, 2015 02:42 PM
robbie374
Jul 7, 2015 02:56 AM
