electrical trouble
Old Feb 28, 2005
tarheel365's Avatar
tarheel365 is an unknown quantity at this point
Exclamation electrical trouble
i hit a huge pothole which rattled everything in my car so much that a couple of crimps that attached my cd player harness to the factory wiring came loose and may have caused a short and blew a fuse.
now i can't use my powerlocks when the ignition is off. also when i open the door...the dome light doesn't go on. the interior lights do work when i turn them on tho.
i checked the #8 fuse and it looked fine....
i'm not really sure what fuse i'm looking for or if thats even the problem. any input would be a great help...thanks
Old Feb 28, 2005
Bires's Avatar
Bires is an unknown quantity at this point
Did you check the fuses under the hood behind the battery?
I blew a fuse in there yesterday when I was futzing around with the my dimmer wire.
Old Feb 28, 2005
darklegacy540's Avatar
darklegacy540 is on a distinguished road
It LOOKED fine.. did you test it though? I've seen fuses that don't look blown but they indeed were..
Old Mar 1, 2005
tarheel365's Avatar
i gotta check under the hood. does anyone know which fuse it is that controls power to the power locks when the car is off?
Old Mar 1, 2005
diskreet's Avatar
check every single one my last car blew the fuse for the window and the horn stopped working too. not only one thing might be on one fuse.
Old Mar 1, 2005
PopcornPlaya's Avatar
Electric Boogaloo...
You have a owner's manual? It tells you which fuse does what, and their location both in the box and in the vehicle (under hood or under dash).
Old Mar 1, 2005
Mystic3030's Avatar
Yup, i'm an A$$hole.
I bet it's the fuse under the hood labeled "backup"
Old Mar 1, 2005
tripledoublegs's Avatar
Euro-Spec
^Yep, that's the one. same thing happened to me a few months ago.
Old Mar 1, 2005
profuse007's Avatar
Senior Member
profuse007 is an unknown quantity at this point
just curious, isnt that the extra fuse you need if one blows out? i think every fuse has a specific label, backup isnt specific.
Old Mar 1, 2005
paradoxblue's Avatar
hehe. i blew a fuse putzin arond ocne
brought it to my dealer they looked and found what i blew and replaced it
i had no running lights and my check engine light wa son ALL the time
Now when i turn my car on.. i have no running lights or nothing unless i manually click them on.. BUT once i drop my ebrake the external lights come on.. is this normal or did i **** something? its nice though cause my car runs to warm up at night and theres no light so no one knows its on
Old Mar 1, 2005
2K1Civic17"Gabe's Avatar
My HU stopped working after I hit a bunch of hard bumps, it was a loose fuse. Make sure none of them are loose, just press them all in under the hood and steering wheel. Might as well try an easy fix first, see if that works.
Old Mar 1, 2005
Mystic3030's Avatar
Nope, it is a hot fuse, not an extra.
Old Mar 1, 2005
profuse007's Avatar
Senior Member
ic, havent look into that yet.
Old Apr 12, 2005
OHERC's Avatar
OHERC is an unknown quantity at this point
You guys are awesome. I found this thread after hours of beating my head against the wall. Damn backup fuse. Honda wouldn't even sell me the wiring diagram
Old Apr 12, 2005
ncirom2003's Avatar
just by a test light for future situations they are cheap at sears or something, hook the alligator clamp to a ground (frame bolt or neg. of battery) and touch BOTH metal points that show at the top of the fuse while its plugged in , if any light up on one side only replace it cus its blown, if neither sides light up then its most likely a fuse in an extra spot not being used, and if ur not sure sometimes u have to move the tip of the test light on the metal a little incase there is crud on it.
cferry7
Oct 18, 2015 06:32 PM
Solo Flow
Oct 4, 2015 07:52 AM
thebmillz
Electronics
Oct 2, 2015 08:38 PM
Nalmonte
Sep 28, 2015 01:10 PM
Bruce2
Sep 27, 2015 08:45 PM
