Interference when rear defroster is on
Old Feb 11, 2005
VTEC01EX's Avatar
VTEC01EX is an unknown quantity at this point
I put some new rear speakers in my car this weekend, and I notice now that when I listen to certain radio stations, the second I turn on my rear defroster I get a ton of static. As soon as I turn it off, it goes back to normal. Has this happened to anyone else? All of the connections seem to be in order in the back.
Old Feb 11, 2005
MegaHurtz's Avatar
probalby has something to do with the fact that the antenna is integrated right into the rear window. if that is the case and i would say almost 100% for sure it is, then you are just gonna have to live with it
Old Feb 11, 2005
VTEC01EX's Avatar
I forgot to mention - this just became a problem after I put in the new speakers. I've had this deck for a few months now without this problem.
Old Feb 12, 2005
AggressiveAdam's Avatar
AggressiveAdam will become famous soon enoughAggressiveAdam will become famous soon enough
funny you mention this
i was listening to 680 AM downtown (traffic station) and I was driving under street car tracks that give me the usual static, turning on the rear defrost really messed it up more.
prolly sometin to do with the attenna in the rear window.
solution, stop listening to radio :P
Old Feb 12, 2005
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
If you've changed the HU, then probably the problem is that you neglected to hook up the powered antenna wire. I had a friend with the same exact thing, when I pulled out his Alpine I found his power antenna wire not connected. I connected it and the defroster didn't cause static anymore.
Old Feb 12, 2005
4Saris's Avatar
4Saris is an unknown quantity at this point
I think the factory colored power wire is green with a yellow stripe, am I correct J187? It significantly helps both AM and FM.
Old Feb 13, 2005
VTEC01EX's Avatar
Oops, I bet I forgot to hook it back up. I redid the harness this weekend as well to correct the hack job I did intially. I'll pull it back out and give it a look - thanks J187!
Old Feb 13, 2005
darklegacy540's Avatar
darklegacy540 is on a distinguished road
hack job?
Old Feb 13, 2005
J187's Avatar
No prob. And yes, you are right about the color.
GolNat
Nov 27, 2018 03:32 PM
Sep 27, 2015 11:33 AM
czarlun
Sep 14, 2015 08:16 PM
Gsxtacy
Sep 12, 2015 01:09 AM
Josh 1973
Sep 7, 2015 10:10 AM
