Mounting XM Antennae
Old Feb 13, 2005
ColtsFan1's Avatar
ColtsFan1 is an unknown quantity at this point
Anyone have an hints on where best to mount the (small black) XM antennae that came with my XM kit (Alpine 9835 controlled)?
Thinking it should be centered at the rear of the roof (right above direct center of back window) - but didn't know if others have placed themin the same spot.
If so, curious as to how to best run the wire. Can it be tucked under the weatherstripping that surrounds the back window?
Help! I've never had satellite radio before. Searched the forums & noone seems to have posted their installation technique for this.
Thanx -
Old Feb 13, 2005
4Saris's Avatar
4Saris is an unknown quantity at this point
It's probably because you are spelling antenna wrong. Try researching under "Sirius Antenna" or "XM Antenna", I found plenty of threads.
Old Feb 13, 2005
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
i made a diy for an xm install, but i lost the pictures, its really easy to run the wire under the weatherstripping
mgrantaz
General
May 2, 2022 05:40 PM
Mad Dog Tannen
Oct 19, 2016 08:12 PM
twd000
Oct 4, 2015 12:52 PM
jackoncruzpr
Sep 29, 2015 07:59 PM
FistRock
Sep 4, 2015 08:00 PM
