sound dampening????????????????????
Old Jan 27, 2005
realitycheck's Avatar
realitycheck is an unknown quantity at this point
Alright I have read so much sound dampening stuff its unreal all of them say something different, this is what I was thinking about doing let me know what you guys think. This is all in the trunk
Alright first get some of the expanding urethane foam that they use to seal pipes and stuff in houses, the stuff in the spray can, squirt this in between all the bracing that is welded to the car in the trunk. Cut off excess then use ice and water guard stick to all panels that I can, then if there is any other places that I cant stick the ice and water guard to something use truck bed liner and paint it on the metal. Alright what do you guys think will it work will it reduce the rattle to a suitable level ???????
Any comments or tips would be greatly appreciated thanks.
Realitycheck
Old Jan 27, 2005
PunkingCivic's Avatar
I need TP for my bunghole
I guess it would work
It should reduce rattle and deaden at the same time
I Just never heard of anyone using foam before.
Yeah, you could use a liquid sound deadner or rhino liner type spray on top of that
Now you have to choose what brand
Old Jan 27, 2005
Or what if you didnt even use the ice and water guard what if you just painted rhino liner on there???
Old Jan 27, 2005
Not sure where you live
If you live in a wet area the the ice water gaurd wouldn't be bad I guess
Sometime bass can flem the trunk lid and might let water in.
but any coating sray should do I would think
Old Jan 27, 2005
Well I live in Alabama, I'm sure I dont have enough bass to make the trunk start leaking I've had my system in for going on about two years now and no problems. Are you saying that adding the rhino liner or something might make it start leaking????
Old Jan 27, 2005
A-A-A-A-A-A-l-l-l-l-r-r-ighty Then!!!!!
Old Jan 27, 2005
darklegacy540's Avatar
darklegacy540 is on a distinguished road
I think that would probably work out alright.. but just on a side note, it's sound DAMPING.. not dampening.. you dampen a sponge.
Old Jan 28, 2005
ahh good spell check. Thanks for the info.
Old Jan 28, 2005
Mystic3030's Avatar
Yup, i'm an A$$hole.
Put the ice and water guard on every surface in the trunk, I would use two-three layers, then do your foam, then use Mar-Hyde rubberized undercoat (found at walmart and major autoparts chains) to coat everything.
Old Jan 28, 2005
Yeah but how can put the foam in the bracings if they are covered in water and ice guard, and I know the rubber coating wont stick to the aluminum sheeting on the water guard will it?????
Old Jan 28, 2005
Mystic3030's Avatar
sure it will...what do you think your car is made out of?
My 1/4 panels are covered in 3 layers of fatmat, then sprayed with GreatStuff foam, and then coated with MarHyde, and then covered in jute carpet padding.
pizzahutcombo
Suspension
Jul 13, 2021 09:41 PM
2005seTO
Aug 18, 2015 12:45 PM
CraigW
Aug 18, 2015 07:06 AM
BootyDo
Jul 26, 2015 10:38 AM
Hqly2001
Jul 25, 2015 05:32 PM
