HU install affects ebrake light?
Old Jan 21, 2005
retro's Avatar
retro is an unknown quantity at this point
Hi,
I bought a new alpine deck and had someone install it for me last week. A few days after my ebrake light started twitching and eventually stays on even though my ebrake is released.
I want to know if there are any wires handled during the deck installation that would affect the ebrake light? If so then I am planning to take it back to the guy who installed it for me because I don't want to take it to Honda and then have them tell me they won't fix it.
thanks~
Old Jan 21, 2005
Akutenshi's Avatar
The Rizing Sun
u kno the same thing happened with me with other parts of the car (ie turn signals, dome light, etc). i kno absolutely jack **** about eletricity n all that crap. but i think its because something with the HU installation touched a ground on the car. n that affected something else that was connected to it.
but then again im probably totally offbase. -____=
Old Jan 21, 2005
82801BA's Avatar
82801BA is an unknown quantity at this point
Well, it probably is not the problem with HU installation. It's the e-brake wire that became loose. Simply remove the cover near the brake handle(in front of the brake handle, a small U shape plastic), and move the connector a little bit so that sits secured. It should work out.
If you need picture, PM me.
Old Jan 21, 2005
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
Undo all the connections made during the install and see if it still happens.
Old Jan 21, 2005
82801BA's Avatar
I can say that I have that problem before, went to the dealer, they told me it's the connector's problem, not installation problem anyway. Don't do too much to it at this point, check the connector first before you put too much time and work in there.
Flipg123
May 22, 2015 10:43 PM
twtron
Apr 17, 2015 12:09 AM
klam
Nov 19, 2001 05:46 AM
klam
Nov 16, 2001 03:36 PM
klam
Nov 15, 2001 05:30 PM
