wiring 2 horns
Old Jan 20, 2005
shmik1's Avatar
wiring 2 horns
I've seen in the DIY there was 2 horns hooked up, I bought an aftermarket horn and it said its made to replace stock and be ran by itself, so what would happen if I ran 2 horns? would it just draw twice as much power, and possibly blow the fuse? or would it only run half power?
Old Jan 21, 2005
nunzio42's Avatar
nunzio42 is an unknown quantity at this point
i would try this in the tech forum, i believe there is a diy for 2 hella horns out there
Old Jan 22, 2005
againifall's Avatar
Go Team Venture!
againifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of light
i have 2 horns.. stock and a dual airhorn.. if yer aftermarket one came with a relay.. just follow the instructions... basicly you just tap into the wire for the stock horn.. connect that to the relay.. connect the horn +/- to the relay.. run a 12v+ from the fusebox to the relay... then ground ground it all out to the frame..
it sounds sorta retarded with two horns.. but i like it.. the airhorn has like a 1second delay cuz the compressor has to build.. but its nice cuz i can chirp the stock horn without the airhorn making any noise.. or i can lay on it and make them both blow..
if i remember correcly the wiring goes something like this
red=+
black=-
1 stick horn with a positive 12v going into it.. it grounds straight to the frame through the mounting bolt
2air compressor ground to the frame
3 the relay
4fusebox under the hood it has 2 nice hookups you can bolt to.. i think i threw a 20 fuse on that line just for kicks..
Old Jan 24, 2005
shmik1's Avatar
yea my question was just is it doable.. I would just splice the power wire and ground it same as stock.. I have an aftermarket horn now but i was originally going to put that + stock, but I just replace it cause the horn i bought said it was meant to REPLACE and it made me think I should only run one.. so basically I was just wondering if anything goes wrong (fuses blowning, etc) if you splice it..
so im assuming thats a no, and just go ahead and wire up to horns
Old Jan 24, 2005
does this mean we have to take the bumper back off You should get the ones inanimatecarbonrod has. His is for sure louder than even two combined.
Old Jan 24, 2005
againifall's Avatar
Go Team Venture!
i can now get my bumper off in under 2 minutes..
if yer lookin for a air horn i think they will all require a second power source.. but the only real place to mount it is like 2 feet from the fuse box so thats easy.. if yer lookin at the electric horns that look like the stock ones.. i think those dont need a second power supply...
i havent had any problems with blowing fuses
18
Aug 17, 2015 08:02 AM
kaashifv
Interior
Jul 27, 2015 05:28 PM
sch2cm
Jul 21, 2015 09:58 PM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
robbie374
Jul 7, 2015 02:56 AM
