Cheapo dynamat material...
Old Jan 15, 2005
mdb_foxmx's Avatar
mdb_foxmx is an unknown quantity at this point
Ok...I know it's not really correct to say this is a Dynamat replacement, as Dynamat does a totally different thing acoustically, but how about this for a poor man...You know that "egg-carton" bed stuff you can buy to put on mattresses to make a soft layer? Well, why couldn't you use that stuff as a noise diffuser? I mean, it's got lots of pores...What do you guys think?
Old Jan 15, 2005
Carpet foam is better and it's cheap and light weight for a noise reducer. Check out www.b-quiet.com for other stuff. It explains the differences.
Old Jan 16, 2005
tbaleno's Avatar
tbaleno is an unknown quantity at this point
Also, dynamat isn't a sound absorbtion material. It is used to firm up flimsy metal so it doesn't rattle as much.
You should probably use it in conjunction with a sound absorbtion material.
Thats only my opinion though.
Old Jan 16, 2005
Yeah dynamat is good for door panels where speakers are installed to make a type of enclosure. It doesn't help road noise. Sound absorbtion mat is more for road noise like accoustic foam, L and V-comp, that kinda thing. Or even carpet foam.
Old Jan 16, 2005
mdb_foxmx's Avatar
Yeah. I knew that about dynamat. I'm trying to get rid of some road noise, mostly. I find that I have to kick the volume up a few notches when I'm on the highway, then when I come to a stop after I exit, it sounds like the radio's blaring...
mohawkboom
138
Aug 25, 2016 09:01 PM
protoCall7
Bolt-on Engine Performance
Jul 26, 2015 07:41 PM
gearbox
15
Jul 20, 2003 07:28 PM
toadsteraz
May 19, 2003 10:59 AM
FurBall
Aug 10, 2002 04:52 PM
