Quick Alarm Help
Old Jan 6, 2005
Dnask8's Avatar
Dnask8 is an unknown quantity at this point
Quick Alarm Help
What is the best way to get at the wires behind the fuse box under the dash? I got an alarm and am doing the install myself and have hit a few snags. Can anyone help?
Old Jan 6, 2005
profuse007's Avatar
Senior Member
profuse007 is an unknown quantity at this point
check out the tech stuff forum. theres a tutorial on how to install alarm
Old Jan 6, 2005
Dnask8's Avatar
Thanks a bunch
Old Jan 13, 2005
sweetcivic03's Avatar
sweetcivic03 is an unknown quantity at this point
there are two screws on the front(gold) that you can loosen and the suse box slides right down
Old Jan 14, 2005
profuse007's Avatar
Senior Member
the neg parking light trigger is easier to find than the one behind the fuse box.
Old Jan 16, 2005
you can only use the neg. parking light trigger if the alarm you are installing has a parking light jumper (either positive o negative)
Old Jan 17, 2005
profuse007's Avatar
Senior Member
most alarm these days will have two options in different ways. if given only (+), you can always reverse teh polarity to (-) w/ a relay.
Tedverseti
Apr 23, 2020 01:45 PM
ricer_em2
May 11, 2016 08:09 PM
frank_kleng
Sep 29, 2015 10:55 PM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
metalpres
Sep 23, 2015 05:22 AM
