For those of you w/one Shiva
Big Member
I am seriously considering making my first sub a shiva...but before I do, I was wondering what type/size enclosure do you have and how much power are you running to it? I want some bass but also some trunk room, so was thinking sealed. Is 200W enough or should I double it and do 400?
7thGen's Loudest Civic...4,000 watts and climbing...
Shivas are made by Adire, right?...the same company that makes the Brahmas?...anyway, just check Adire Audio's web site, or go to SoundDomain.com , click "Member Pages", then search for systems...one of the 3 or 4 pull-down menus is for searching by product and category...select "subwoofer" and "Adire", and then just see what everyone else has done...hope this helps...good luck!
Electric Boogaloo...
www.adireaudio.com That's their website, they should have the specs for them there, along with simple box plans. Several members here run them with JBL power series amps with great results. The reason for the JBL is because you get cheap, but very decent clean power.
I am running a single shiva and I'm running it off of a JBL 600.1 which puts out 300w at 4ohm's. The enclosure should be 1.8cubic feet sealed. Do some simple math and find out what shape you want it to be.
The spec sheet of their site says that the max the shiva takes is 650watts, but that is when it reaches its thermal limit. DO NOT TRY TO PUSH 650 WATTS THROUGH A SHIVA. It would be bad. The max I'd recommend is 400ish watts. I'd say, though, that you'd want at least 300watts if you like your bass.
Make sure the gain on the amp matches the voltage output on your headunit, and don't turn up the bass on the equilizer (random important thought).
The shiva is a great sub. It's not the loudest, but it hits very deep and can still keep up with the double bass in any hardcore/metal I throw at it. No one who has listened to my car has commented about me having a shitty sub.
Just some thoughts.
Just some thoughts.
My Shiva is powered by a PG Xenon X400.1 (400 watts) - I would also agree that any more than 400 watts would be a bit too much. This Shiva is a great first sub (it's my first car sub) - I still haven't gotten around to taking pictures of my set-up - once I do I'll post them so you can see my box and such - I have a good amount of trunk room.
1.8 cu ft sounds big. For a 12"? I have my 12" in a 1 cu ft box and it sounds awesome. I mean I know every sub has different specs but that box is 80% bigger than mine!!
What could cause two speakers of the same size to require different size boxes?
Originally Posted by patau13
Ed, How does it sound w/only 150W?
It sounds wonderful. I don't really need it to go any louder, stuff vibrates and it gets embarassing before the amp runs out of juice.
i boogie for the raindrops
faultyscrew
Jul 15, 2004 12:51 AM
TrippinOvaNuttin
Oct 24, 2003 04:57 PM
