Sub Suggestion, replace Shiva
Old Jun 4, 2004
Ed's Avatar
Ed
Well, I decided that as much as I love the sound of the Shiva now, I need a little more trunk space. I plan on fiberglassing something into the side of hte trunk, but at 1.8 cubes, It might too big to look a little stealth.
I'm looking for something that will sound as low as the Shiva in less airspace, around 1 cube if possible. I don't want to spend too much, around $100 at most. And, I'm only using about 200 watts rms at 4 ohms.
It isn't a big deal to me what size speaker it is, but 12" at most.
Thanks for any suggestions!!!
Edward
Old Jun 4, 2004
doubledeuce2k2's Avatar
try image dynamics ID10 or IDQ10 maybe
Old Jun 4, 2004
PopcornPlaya's Avatar
Electric Boogaloo...
The sub that's coming to mind for me right now is an Image Dynamics IDQ10D4v2. It works well in small airspace, and doesn't require that much amplification. Not sure if you can find one for that dollar amount without going through ebay though. Another option is the ID10v2 Dual 4 sub. I'm positive you can get it for under $100, and it works as well in small airspace, plus it would work great on 200 watts, being as its rated 175 and 300 max. Those would be my option if you're looking to step down enclosure size. JL work well in small enclosure, but I doubt you'd find much more than the entry level W0 for that amount (unless you find a steal on something such as a W3v2 or W6v2 on ebay, but the downside is they don't authorize online sales, so whatever you got, you'd be stuck with and they wouldn't have to honor the warranty). I haven't really looked into small enclosure subs that much, and haven't worked with a lot of other product, so I'm kind of hard pressed looking. Hopefully someone else with more experiance in those areas might be able to give you a little more insight. Good luck, and keep us updated on what you find, and decide.
Old Jun 4, 2004
fonto's Avatar
The LA Clipper
When i saw the subject I thought to myself, "i hope his reasons are space issues, because that is theonly reason he should give up the shiva"...and so they are...
I think the ID is a good choice...or maybe a W3 v.2 or an Infinity Perfect 12"....the Infinty can play pretty low compared to most in a sealed box.
Old Jun 4, 2004
Ed's Avatar
Ed
Thanks for all the replies I'll look into an IDQ10, possibly 12. Thanks!!
Ed
Old Jun 4, 2004
fonto's Avatar
The LA Clipper
There on sale right now at Sounddomain for $159(I think a new version is coming out soon).
Pricematch at Sounddomain...that way you get a good deal....I'm tellin you I got my Infinity perfect 6.1 for $211 total, each IDMAX for $279 total, and my JBL BPX 600.2 for less then $300.
Old Jun 5, 2004
IDQ10D4v2 for 146.95 shipped if you nede to price match:
http://www.audio-n-more.com/Image_Dy...ar_audio.shtml
Old Jun 5, 2004
LudlamTheory's Avatar
i boogie for the raindrops
idv3 will perform how you want it, idq will sound beautifully, but with slightly less output.
Old Jun 5, 2004
WhiteRabbit's Avatar
for that extra low frequency response, check out the 87 series eclipse woofers
Old Jun 6, 2004
Ed's Avatar
Ed
Where does one buy an Eclipse? I could try my localdealer.. but it sounds like it would be expensive, i saw that i think the 10 or 12 was 170 MSRP.
I'm bidding on an IDQ 12 online right now for about 76, plus shipping, what do you think?
Old Jun 6, 2004
Mystic3030's Avatar
Yup, i'm an A$$hole.
w3v2's sound mediocre in 1 cube, you need at least 1.15 to sound optimum. You could also look into Alpine Type R's, they sound good in .75. the IDQ will probably sound better though.
Old Jun 6, 2004
try ebay for the eclipse woofers
Old Jun 6, 2004
Ed's Avatar
Ed
What do you think of an ID10V3, SD has a factory reconed one for only $79.95, new for $129, minues a 15% discount, free shipping I think..
Old Jun 6, 2004
that sounds like a pretty good deal to me, esp. with a warranty of some kind
Old Jun 7, 2004
Ed's Avatar
Ed
Hmm. the refurbished ID10 V3 is $80 with a 3 month warranty, the new is $100 with a 2 year warranty. The ID12 is $90 refurbushed, $135 new. Is the $20/45 worth saving? Will the 12 sound noticably lower?
Old Jun 7, 2004
also cone area advantage, giving you that little extra oomf
R3KogHyZe
21
Feb 3, 2016 09:23 PM
jc33312
May 12, 2015 03:17 PM
thesushiboy
Apr 12, 2015 02:54 AM
ademarco6
Nov 16, 2001 10:19 PM
ademarco6
Nov 12, 2001 06:52 PM
