Lighting help
Old Dec 8, 2004
armjr2's Avatar
armjr2 is an unknown quantity at this point
Lighting help
I need some help I tried to finger this out but i cant I was re-aiming my headlights and all if sudden the driver side low beam goes dim but the right side low beam remains fully lit. But the two high beams are on also but are on low power(half way lit). I have projector lights. i though it was the projectors so I install the factor light and the same thing happen. The high beams being half way lit would be fine only if both of the low beams were fully lit. The projectors worked fine and where installed some months ago. Any help would be great.
Old Dec 8, 2004
wonderz's Avatar
wonderz is on a distinguished road
did you check the fuse?
Old Dec 8, 2004
armjr2's Avatar
if it was the fuse, wouldnt it be either on or off? the power flow has just been decrease to that one light
Old Dec 8, 2004
armjr2's Avatar
ok i fix it stuid fuse blew
MyCivic
Electrical
Oct 28, 2021 11:06 PM
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
werdnahall
May 17, 2015 11:37 AM
davidarenberg
May 16, 2015 08:45 AM
klam
Nov 16, 2001 03:36 PM
