Center console wiring
Old Nov 22, 2004
bakuretsu's Avatar
bakuretsu is an unknown quantity at this point
I am going to be wiring up some lights and such pretty soon, and I wonder if anyone has any guides or information for me regarding the bird's nest of wiring inside the center console.
I can obviously pull +12v from the accessory outlet, but I don't want to use that one source all the time, it would be nice to know of others... Without disassembling my entire car and tracing every wire.
Where have you tapped into for power in the front of your cars?
Also, if I were to splice into the +12v accessory outlet line to power my sound-reactive EL wire, would the varying voltage being pulled by that system affect the other junk I'll have plugged into the outlet, such as my iPod and radar detector?
Old Nov 22, 2004
PopcornPlaya's Avatar
Electric Boogaloo...
You could also use the acc wire on the ignition.
Old Nov 23, 2004
2slow2run's Avatar
wut time is it now
2slow2run is an unknown quantity at this point
dammit just use use the same power as the cig...works for me
ok find...trace it thru ur deck power wire ahahha
probably fry that sob
Old Nov 24, 2004
ashtonp's Avatar
ashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to behold
use the same wire as in the acc. outlet, but if your paranoid about it run a relay to be safe, I ran a relay from my HU's remote wire to control all my amps
Dani1993
Jul 24, 2015 09:02 AM
Roman Rembacz
Jul 16, 2015 12:30 PM
muttleytm
Jul 11, 2015 06:00 PM
CivicsClass101
Jul 9, 2015 11:14 AM
robbie374
Jul 7, 2015 02:56 AM
