Need some brain power - In dash DVD
Old Nov 15, 2004
blustreakn01's Avatar
blustreakn01 is an unknown quantity at this point
trying to install sick in dash DVD/MP3/VCD player and need some help. dmn thing won't play picture while in motion - must have parking brake enabled.
Anyone have any ideas about by-passing this fail safe?
I've tried wiring straight to ACC and about everywhere else I can think of? The two leads causing probs are the one that is supposed to be wired to backup terminal and 1 that is to be wired to the parking brake term?
Any thoughts!?!?!?
Old Nov 15, 2004
usafcushman's Avatar
7thGen's Loudest Civic...4,000 watts and climbing...
usafcushman is on a distinguished road
just ground the one that is supposed to be hooked up to the parking brake and you should be good to go...if that doesn't work, you should post make/model etc. so we can give you a definite answer...hope this helps...good luck!
Old Nov 15, 2004
Rufus's Avatar
If it's an alpine, I have a bypass for it.
Old Nov 15, 2004
It's a clarion. What's involved in the bypass? Is it something I can wire, or do I need to order?
Thnx for the help!
Old Nov 15, 2004
Tried to ground parking brake lead - blown fuse!
Willing to try any other ideas - I've exhausted all mine! Thnx for the help!
Old Nov 16, 2004
Mystic3030's Avatar
Yup, i'm an A$$hole.
you need to ground it...you said you hooked to ACC and thats power.
Old Nov 16, 2004
Prior to trying to ground it, I tried the accessory. Neither worked initially.
Problem has been solved - Parking brake lead needed its own stand alone ground - initial attempt was to splice into main ground. Stand alone ground solved the problem.
thanks to all for the input!
Old Nov 16, 2004
oops...sorry about the fuse, i reckon i could have been a little more specific about the ground...glad to hear you got your stuff working though...
Kyle Cargazm
Jul 4, 2015 05:32 PM
HiImBrandon
Jun 1, 2015 07:34 AM
SSMatey
Apr 13, 2015 06:09 PM
SLeePeR012
Jan 7, 2002 12:24 AM
