polyfill
Old Oct 29, 2004
ohiojosh78's Avatar
ohiojosh78 can only hope to improve
polyfill
I've never, in 10 yrs, worked with polyfill. Now, i've seen articles about how much to put in boxes(1lb/cubic foot) but thats about all i know. I'm not going to be using any, never have. I'm just curious.
1.) How do you install it? with spray adhesive?
2.) Does installing polyfill change tuning frequency for ported enclosures?
3.) It does go on the inside of the box right
Old Oct 29, 2004
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
http://www.win.net/audtatious/audio/fiber.html
Old Oct 29, 2004
HondaSales's Avatar
HondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of light
you can buy it at any "rag" shop. it supposedly adds volume to the box and will probably change the tuning frequency.
wish i could view the link that J187 posted but its blocked by websense here at work...
Old Oct 29, 2004
ohiojosh78's Avatar
yea, the amount to put in is the only part i know. but does it effect tuning? and how should it be put in the box as far as how to make it stay in place.
Old Oct 29, 2004
HondaSales's Avatar
just stuff it in. i'm sure you'll have to somehow make sure it doesn't get caught up in the voicecoils..
Old Oct 29, 2004
MegaHurtz's Avatar
It may make the box seem bigger but as far as changing the tuning goes, it will probably change the tuning becuase the box is actually SMALLER because of the displacment of the polyfill... I couldn't see some cheap material making the box SEEM bigger actually changing the tuning becuase the formula doesn't change.
You could probably adhesive it to your box if you wanted, but personally I just stuff it in, doesn't matter. 1lb is a lot, I just put it in as I see fit, maybe fill it 1/3 or so up
Old Oct 29, 2004
ohiojosh78's Avatar
Thats what i was thinking also. as far as not really changing the tuning frequency and it did also seem quite a bit of polyfill. 5lbs for a 5 cubic foot box would be like a trash bag full of polyfill.
Old Oct 30, 2004
MegaHurtz's Avatar
I would think even more... polyfill is super light stuff, 1lb especially when fluffed out seems like an exorbatant amount to me
Old Oct 30, 2004
J187's Avatar
You don't want to glue it all down though, it is the moving of fibers that makes the heat dissipate and create the illusion of a larger box.
Old Oct 31, 2004
thom's Avatar
/////ALPINE
i did it .
sounds better.
1 lb per square feet
5peed|2acer
Jul 10, 2006 03:41 PM
iLLuMiNaTi
Oct 29, 2005 02:15 AM
doubledeuce2k2
Nov 5, 2003 01:53 PM
cdmx
Feb 19, 2003 10:40 PM
mohawkboom
Mar 13, 2002 12:47 PM
