quick question?
Old Oct 24, 2004
jmaz's Avatar
jmaz is an unknown quantity at this point
quick question?
are you guys fans Equalizers? what brand?
Old Oct 24, 2004
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
Fan, not exactly. YOu shouldn't be using an EQ to fix anything, only to fine-tune things that just aren't quite there. In another words, your system sounds good already, just not quite how you want it exactly. Remember, the less powered devices like eqs and processors that you have, the lower your noise floor will be. High noise floor is bad, mmmmkay? So My advice is if you're having trouble with your system, fix it the right way, by tuning, changing the install or swapping some pieces out. What exactly is giong on with your sound why you feel you need an eq.
Old Oct 24, 2004
jmaz's Avatar
actually i was just courious about what people thought of them. you basically answered my question. thanks
Old Oct 24, 2004
brash's Avatar
brash is an unknown quantity at this point
Well, I'd say you are using an EQ to fix things, though I also agree with J187 that it is a fine-tuning kind of fixing, not a cure for bad speakers or bad imaging or whatever.
The point of an EQ is to flatten out the sound, to fix any minor problems with your speakers or environment (i.e. car) that cause you to lose or boost some frequencies.
Old Oct 24, 2004
darklegacy540's Avatar
darklegacy540 is on a distinguished road
An EQ basically adjusts the gain on certain frequencies. I personally am an EQ fan but only in the correct install.
CraigW
Aug 18, 2015 07:06 AM
civic98?
Aug 13, 2015 01:32 AM
Strycker
Aug 2, 2015 08:40 PM
sam31444
ECU Fried
Jul 20, 2015 08:31 AM
NoobyKid
Jul 13, 2015 07:53 AM
