Test tones
Old Oct 16, 2004
fonto's Avatar
The LA Clipper
Test tones
Can test tones be played by tweeters at moderate volumes...or is this a bad idea?
Old Oct 16, 2004
tbaleno's Avatar
tbaleno is an unknown quantity at this point
Good question. I'd like to know the answer to this as well. I would assume if the tweeter was made to play that frequency it shouldn't be a problem.
Old Oct 16, 2004
MegaHurtz's Avatar
Technically they could but why would you want them to
Old Oct 16, 2004
fonto's Avatar
The LA Clipper
I don't want to go any higher then 6400hrtz in frequency...but I want to test my systems frequency response.
I have done it from 20Hrtz-200hrtz, but never above. I mainly want to check the midrange.
Old Oct 16, 2004
darklegacy540's Avatar
darklegacy540 is on a distinguished road
That's fine. Your tweeters should have either a passive or an active cross over to them so you can't damage them. At IASCA competitions (Mainly SQ competitions), they use test tone cds.
Old Oct 17, 2004
IronFist's Avatar
Where do you get test tones?
Old Oct 17, 2004
fonto's Avatar
The LA Clipper
I downloaded a program that I found on google and made my own
Old Oct 17, 2004
Well IASCA uses their own test tones cd. However, you can pick up a test tones cd just about at any cd store.. Sam Goody, etc. Ask an associate for the "bass cd section" Check for a cd with tones.. usually a cd with around 100 tracks or so. I know Bass Mekanik makes a couple.
Old Oct 17, 2004
fonto's Avatar
The LA Clipper
They do, but these CDs typically do not have midrange frequencies...only bass.
Old Oct 17, 2004
IronFist's Avatar
100 Tracks? Is it like 100 different frequencies of sine waves?
Old Oct 17, 2004
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
http://www.sounddomain.com/shop/item...DSV50&ref=amzn
Old Oct 17, 2004
fonto's Avatar
The LA Clipper
I have that CD, and no it does not have any test tone above 100 hrtz
I have another Bass Mechanik CD that goes up to 200 hrtz.
BTW, it was not a good idea to play test tones at high frequencies...I almost went deaf!!
Old Oct 17, 2004
J187's Avatar
LOL
I don't even have that CD, I just found the link on a search. I've got one from . . . Damn I can't remember.
Old Oct 17, 2004
tbaleno's Avatar
Here is a program to generate tones and store them in .wav files so you can burn them to cd. It runs on linux and windows.
http://wavb.sourceforge.net
cukaracha
Aug 27, 2015 02:02 AM
alinaray
18
Aug 24, 2015 01:04 PM
martinsmartin
Aug 15, 2015 07:34 PM
USCGBM
Aug 12, 2015 04:22 PM
Civicircus
Aug 6, 2015 11:58 PM
