Nakamichi CD400 problem playing burnt cd
Old Oct 16, 2004
XSRCivic's Avatar
XSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really nice
Hey guys I was wondering if any body had any problems with playing burned cds. I burn a new cd, throw it in the Naka and it skips like somebody took a knife and carved there name in it or it just spits it back out. Ok now get this, I take the cd out rub it on the seat a few times and bam it works.. wtf?
I bought a new cd burner awhile back so could that be the problem. I tried ashampoo cd burning software and also tried win media player and the same thing happens. Does the write speed matter when you burn a cd because I want it to burn as fast as it can. Rubbing the cd on the seat helps most of the time but damn I shouldnt have to do that. Any help would be greatly appreciated.
-matt
Old Oct 16, 2004
MegaHurtz's Avatar
Write speed can make a difference, I've found that CD's generally worked better when burned at a slower speed. Highest speed I will burn anything at is 16x. Anything faster is just a marketing gimmick
Old Oct 16, 2004
darklegacy540's Avatar
darklegacy540 is on a distinguished road
I usually don't burn anything faster than 8x just for that reason.
Old Oct 16, 2004
XSRCivic's Avatar
i thought that might be the prob but i also tried a cd that my friend burned at 4x i believe, it did not work either..
Old Oct 17, 2004
MassMayhem's Avatar
MassMayhem is an unknown quantity at this point
First time you use a cd/cd-r rub a pencil eraser around the inside and outside edge. Should solve the problem. I have seen only about 3 or 4 times in the 3 years Cd-r's have been around that your problem occurs. Bizarre.
ClapAlongChorus
Electrical
Oct 28, 2021 10:50 PM
MiniMi
May 27, 2015 01:57 PM
ywgflyer
May 15, 2015 05:05 PM
PimpBot5000
Nov 26, 2001 07:15 PM
