DIY: Head unit install
Old Oct 2, 2010
  #181
kofrad's Avatar
kofrad is an unknown quantity at this point
Re: DIY: Head unit install
To update my situation, the piece I am missing is the head unit wiring harness. That piece was discontinued by the manufacturer so I will be heading out to local shops later on today to see if I can find a generic harness that will fit my new HU.
If I get a generic harness, will I need to re-wire it?
Old Oct 2, 2010
  #182
kofrad's Avatar
And the final update. I did get my hands on the HU wiring harness, did my wiring and successfully mounted the new HU in my civic.
Once again great DIY, really got me on the right track!
Old Dec 10, 2010
  #183
notmine's Avatar
notmine is an unknown quantity at this point
just did my install last night. new head unit being a kenwood kdc-hd545u.
everything went fine but am left with a minor issue.
I noticed that not all the center console HVAC lights are coming on properly.
By on, i mean illuminating like they normally do when the headlights are turned out.
The top left **** (vent output selector) works perfectly and illuminates entirely.
The middle left (temp control) only illuminates in the top half.
The other **** and buttons (fan speed, vent closed/open, AC and defroster) don't illuminate at all.
The button lights(not illumination but the actual small lights) work when clicked on.
the install was done using the crutchfield supplied wiring harness going to the stock harness.
Don't know what I could have missed or done wrong for this to happen.
Any ideas?
oh, and car is a 2005 civic ex sedan if it matters.
Old Dec 10, 2010
  #184
CraigW's Avatar
^^^ check your connectors to make sure they were put back properly and order some replacement neo-wedge bulbs. I replaced all of mine at once on my 05.
Old Dec 10, 2010
  #185
electric130's Avatar
Any ideas?
did you connect the "illumination wire? I hope not.
Old Jan 5, 2011
  #186
DewHead's Avatar
DewHead is an unknown quantity at this point
Ok I want to get this straight, do you leave the illumination wire or the dimmer wire unconnected? Or not connect either?
Orange = illumination
Orange/white = dimmer.
Thanks guys.
Old Jan 5, 2011
  #187
be safe....neither.
Old Jan 5, 2011
  #188
DewHead's Avatar
Ok thanks, what a strange problem for the wiring to have. Glad I perused here before getting to it that would have been an unnecessary pain.
Old Feb 9, 2011
  #189
Alumnite's Avatar
Alumnite is an unknown quantity at this point
Where are the pictures for this tutorial? Does anyone have the pictures or a video on this tutorial? Please let me know ASAP!
Old Feb 10, 2011
  #190
DarkSouljur's Avatar
DarkSouljur has a spectacular aura aboutDarkSouljur has a spectacular aura about
I found these vids on youtube
http://www.youtube.com/watch?v=vJBDj...feature=fvwrel
But there are 2 more parts, this tutorial is for an automatic trans.
Goodluck with his accent
Old Apr 9, 2011
  #191
tkrotchko's Avatar
tkrotchko will become famous soon enough
Thanks guys.
I don't think you have that quite right. On a '98 accord, Orange = dash lights plus dimmer, Orange/white is 1.5 constant voltage when lights are turned on.
Most DVD/Nav units are going to require Orange/white. If you're not sure, get a volt meter and check it.
I would also look on the harness of your head unit, since Orange & Orange/White seem to be a universal color code for all audio installations.
Old Apr 9, 2011
  #192
this isn't an accord forum, it's a 7th gen civic forum. they're different. if you connect the illumination wire on aftermarket HU's to a 7th gen civic, it fries part of your dash lighting.
Old Apr 9, 2011
  #193
tkrotchko's Avatar
My favorite is that he's not wearing any shoes.
Old Apr 9, 2011
  #194
tkrotchko's Avatar
Again, I would get the volt-meter and test the voltages, it will take 5 minutes. If you get a steady 1.5v on the orange/white, it is used by head units to dim the lighting in the controls when you turn on the lights, which is a quite valuable safety and convenience feature.
If you don't get 1.5v, then you know its not correct.
Old Apr 9, 2011
  #195
tkrotchko's Avatar
You're pretty knowledgeable, so I've got a question on installing a double-din unit in a 7th gen civic.
Do you have any experience with the after-market trim kits, and which one will give me the most stock look when installed?
Also, in this year of car, do you use the DIN sleeve to hang it from the dash? Is the Honda Scosche mounting kit preferred? (I'm asking because I've found in most cases, the only use of these kits is the trim ring to finish that job)
Thanks for any advice.
Old Apr 9, 2011
  #196
most kits will be a basic black textured plastic. they won't match your dash perfectly. if you want that, i'd say do some bondo/fiber glass work on the trim and paint it to match your dash. I don't know off hand with a double DIN, but the single DIN i put in, i had to use the metal sleeve that you bend the tabs up into the mounting bracket. tough to get a jiggle-free install. I think most on here get the Metra double din, not the Scosche. hope that helps
Old Apr 16, 2011
  #197
uliraf's Avatar
uliraf is an unknown quantity at this point
Hi guys. i am looking for A/C power unit electrical diagram. the old one was robbed and the new one came with a different harness and i don't know how plugging the cables or the color in each pin. i will appreciate your help.
Old Apr 16, 2011
  #198
BiggSean's Avatar
BiggSean is an unknown quantity at this point
I'm going to install a double din JVC radio into my 05 Special Edition Coupe next weekend.
My Special Edition came with the factory double din radio. Due to the fact that my original radio was double din, do I simply reuse the mounting brackets from the factory radio? Do I need anything aside from a wire harness to do the install?
Thanks in advance. I need to order my install parts this weekend so I can get them in time.
Old Apr 18, 2011
  #199
You will likely still need a mounting kit
Old Apr 18, 2011
  #200
BiggSean's Avatar
According to this, this metra double din install kit applies to all Civics, except the Special Edition, which leads me to believe that I probably don't need a mounting kit:
http://www.amazon.com/Metra-95-7899-.../dp/B001JT12OO
Can anybody with a Special Edition confirm?
Old Apr 19, 2011
  #201
tkrotchko's Avatar
I just installed a double-DIN nav system (Pioneer AVIC-X930BT) in a 2003 civic sedan. A couple notes:
1) I used a double-DIN mounting kit I purchased on ebay, from American International (www.aius.net). It looks decent, has a good color match, and fits the hole well. But the DIN opening is slightly over-sized and I had to put black material to hide the gaps. This particular bezel does not show up on their web site, however.
2) For Dash illumination, The standard orange/white wire does not put out enough voltage (less than 1/10th of a volt) to kick in the night model on the AVIC, however, I tried the orange wire and this worked quite well (note that when I say orange or orange/white, I'm not referring to the Honda wire color codes, rather the standard A/V codes that seem to be nearly universal these days). The Pioneer makes the sky turn dark and puts stars in the sky at night.
3) Thanks to folks help, tying into the VSS from the ECM was a piece of cake. 05Reverb turned a long-drawn out procedure into 5 minutes of work.
The Pioneer is nice, although it will not let you do much "stuff" when the car is moving. I am not pleased with this aspect of it.
Old Apr 19, 2011
  #202
im sure there is a bypass for that unless the unit has some sort of new movement technology i dont know about. usually its a simple matter of finding the right wire and grounding it. people with dvd players do this all the time.
Old Apr 20, 2011
  #203
tkrotchko's Avatar
I found the bypass, and tested it out. It added one quirk; the speedometer stopped working, so I pulled the VSS wire off the harness. I can live without that. It also popped a code simultaneously, a P1457, which usually means the gas cap is loose.
I reset the code and hopefully, all will be well.
If people are interested in the bypass, just look up AVIC-X930BT Bypass on Youtube. Almost all of the guys (with the exception of the older gentlemen) are goofballs that take 5 minutes to tell you 30 seconds worth of material .
Old Nov 8, 2011
  #204
DannyM91's Avatar
DannyM91 is an unknown quantity at this point
Hi guys, looking for a bit of help here. Just bought an 05 civic sport at the weekend and looking for a bit of help putting the new head unit in and wiring up my sub and amp.
Not bought the Head Unit yet, so any recommendations would be great, cheers.
4 banger
Jun 5, 2015 01:44 AM
HondaHomer
May 14, 2015 12:24 PM
mugenca
Apr 16, 2015 12:15 AM
mwwhonda
Dec 5, 2001 10:52 AM
PimpBot5000
Nov 26, 2001 07:15 PM
