problem with system install
Old Oct 2, 2004
Hardhittinz's Avatar
Hardhittinz is an unknown quantity at this point
Today i had a headunit installed a amp and sub in my 2004 civic ex auto at a well know (to my area) shop and i was so busy messin with the radio as i left the shop not to notice that my Air Bag light and seat belt light are both on now...they guy installed the amp under the passenger seat so the seat was taken out to do this..What do you guys think could be causing these 2 lights?
Old Oct 2, 2004
MegaHurtz's Avatar
They probably unplugged the sensors that were down there and forgot to plug them back in. OR they did plug them back in but they still threw a code that will need to be reset.
Old Oct 2, 2004
sensor for what the seat belt thing or air bag? and the thing is the shop is closed until monday so what do u think i should do?
Old Oct 2, 2004
MegaHurtz's Avatar
Check under your seat and see if any thing is unplugged....
Old Oct 2, 2004
yea everything is plugged in
Old Oct 2, 2004
so if everything is plugged up and it did throw a code i would get my airbag light and seat belt light?
Old Oct 2, 2004
Mystic3030's Avatar
Yup, i'm an A$$hole.
If they took your seat out with the battery connected it will do that. Just go back monday...its not gonna cause a problem with the car.
Old Oct 2, 2004
so is there anyway i could reset something???? or better just to go back to the stereo shop?
Old Oct 2, 2004
MegaHurtz's Avatar
I believe they will have to reset it with a code reader which should be done at the shops expense
Old Oct 2, 2004
Mystic3030's Avatar
no you can do it with a paperclip...search the site, theres a DIY on it.
Old Oct 2, 2004
MegaHurtz's Avatar
LOL real nice
Old Oct 3, 2004
vivid_BLUE's Avatar
make it a habit
vivid_BLUE will become famous soon enough
what would one type in the search box to find this DIY?
Old Oct 3, 2004
Mystic3030's Avatar
Go to tech stuff > DIY's > Electronics > Reset your SRS light
Or, you could follow the link here that I have so graciously provided.
http://www.7thgencivic.com/forums/sh...d.php?t=155251
Old Oct 3, 2004
vivid_BLUE's Avatar
make it a habit
thanks
Old Oct 3, 2004
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
Good job guys, I don't know where you are, but its not even legal in MA to release a car back to a customer with an SRS light on. I find it hard to beleive that yours is the first 04 civic they have done! THe DIY works well, I did it myself. Don't bother buying the harness or whatever, just use a small paper clip, make sure its a small one and it'll actually stick right in the connector.
Old Oct 3, 2004
catalin's Avatar
catalin is an unknown quantity at this point
Sometimes simply disconnecting the battery and re-connecting it after a couple of minutes will also tunr off the lights.
What most likely happened is that they installed the amp and then tested it by turning the key on with the plugs disconnected. The vehicle computer, upon ignition turn on, detected this and illuminated the lights in the dash.
Old Oct 3, 2004
Mystic3030's Avatar
The SRS light isnt helped by that, the error is stored in memory that doesnt erase.
Old Oct 4, 2004
catalin's Avatar
True... but I have managed to turn them off in that way, sometimes.
Old Oct 4, 2004
J187's Avatar
Honda is a pain in the ***. The SRS light doesn't show up on any diagnostic computers. Not even the factory honda one
Youshoe
May 22, 2015 09:36 PM
tylerginevan
Apr 27, 2015 12:29 PM
kanin247
Bolt-on Engine Performance
Apr 25, 2015 05:44 AM
Flatlander
Nov 16, 2001 05:38 PM
viper775
Nov 8, 2001 09:14 PM
