quick capacitor Q
Old Sep 27, 2004
speshL K's Avatar
speshL K is an unknown quantity at this point
quick capacitor Q
dus it go battery, CAPACITOR, amp, subs?
or... battery, AMP, capacitor, subs?
Old Sep 27, 2004
Ed's Avatar
Ed
battery, cap, amp, subs
Old Sep 27, 2004
alex053's Avatar
cap before the amp.
Old Sep 27, 2004
speshL K's Avatar
koo thnx guys
Old Sep 27, 2004
tbaleno's Avatar
tbaleno is an unknown quantity at this point
Becareful with that cap once its charged. It holds the charge even with the car off and the battery disconnected. I don't mean to treat you like your stupid but the question you asked leads me to believe you don't know about capacitors and you may need to be warned.
Old Sep 27, 2004
speshL K's Avatar
so ur saying.. becareful while connecting? or be careful wen taking off? or be careful not to touch?
Old Sep 27, 2004
speshL K's Avatar
gotcha while connecting right?
Old Sep 27, 2004
MegaHurtz's Avatar
after its connected be careful
touch the terminals and prepare to meet your maker
Old Sep 27, 2004
irishtemper's Avatar
irishtemper has a spectacular aura aboutirishtemper has a spectacular aura about
bzzzzzzzzzzzzzzzzzzzzzzzt nothing like a high volt charge. painfull I might add. kids in school used to charge them up and stick people with them. I never did it, but I got zapped from a cap from a flash camera. Makes a nice stun gun also.
Old Sep 27, 2004
tbaleno's Avatar
All of the above. be careful while connecting, be careful wen taking off, be careful not to touch.
I guess its a good thing I brought it up.
Old Sep 27, 2004
shmik1's Avatar
just remember ground goes on last (installing) and ground comes off first (uninstalling)
and wut they're saying is, once ur capacitor is installed, and you unground your stock battery, your electrical system still has power from the capacitor..
Old Sep 27, 2004
turboslug's Avatar
Super Hoser
turboslug will become famous soon enoughturboslug will become famous soon enough
the large caps used in car audio are not high voltage...it shouldn't go above 14volts.
if the cap gets shorted, there'll be a large current as the capacitor drains itself. there'll be sparks and i guess, whatever that's shorting it, will get pretty hot.
Old Sep 27, 2004
turboslug's Avatar
Super Hoser
not sure what you're trying to say, but you wont feel a shock if you use your hand to touch the two terminals on the capacitor. the capacitor is wired in parallel to the battery so it's around 12-14volts across the capacitor. unless you have super sweaty and salty hands, you shouldnt feel a jolt.
Old Sep 27, 2004
doubledeuce2k2's Avatar
try peeing on it though
Old Sep 27, 2004
turboslug's Avatar
Super Hoser
heheh...i think you'd still have to have some part of your body planted onto the chassis to feel something...
Old Sep 28, 2004
Havok2k1's Avatar
Wicked Pissah Admin
Don't let anyone fool ya, it gives you a good jolt when you touch both with the same hand.... Trust me, I'm dumb enough to do it....
Old Sep 28, 2004
alex053's Avatar
after you take it off clip one end of a test light to the negative, then touch the other end to the positive...when the light goes out youre safe.
Old Sep 28, 2004
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
If you'd like to prepare for any accidental touching of the capacitor terminals, you could spend a week starting each day by holding a 9 volt battery to your tongue. Then, in the event you accidentally touch the terminals installing you cap, you'll be used to the little jolt you may get. Seriously though,
You also should know to keep wires (and subsequently the distance from the amp) as short as you can. Charge the cap slowly if it needs charging with a resisitor of 10watts and at least 10ohms. Definitely slow-charge the cap, a long time ago I had a shop install my equipment and when I looked at my cap the terms will rusted and oxidized - bastards fast-charged my cap, urrrrr. Anyway, if you've got a 1/2 Farad cap or similar and your using multiple amps, you may want to only use the cap on the sub-amp if it isn't adequate to benefit both amps.
BTW, theres lots of contraversy as to whether or not caps do anything for car audio.
J
Tedverseti
Apr 23, 2020 01:45 PM
ricer_em2
May 11, 2016 08:09 PM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
metalpres
Sep 23, 2015 05:22 AM
