stock HU
Old Aug 29, 2004
VP Stylee's Avatar
VP Stylee is an unknown quantity at this point
stock HU
how do i take it out i searched for a DIY but i kept getting a 404 error when i loaded it. im installing my system peice by peice and today is time to install tha RCA cables.
Old Aug 29, 2004
SiG's Avatar
SiG
what yr is your car?If you're wondering how to get everything out, HU and the pocket underneath, this should help.
On my 2003, you have to take off the stuff in the center around the shifter, unscrew that, and then take out the bolts above the cupholder/under the HU/pocket. There should be three screws to my recollection.
then, with all your power, PULL. The whole middle part, where the radio and pocket are, should fall out if you pull hard enough. BTW, You'll be pulling from where you just got the bolts out from, above the cupholder. If you want, wrap a flathead screwdriver with a cloth. Then, loosen the HU/pocket part by prying a bit. then when you pull, it'll come out easier. The first time will be the most difficult cuz its never been done before. [You are wrapping the screwdriver to avoid scratching your interior peices].
Once the HU/pocket are out its pretty simple. Just take the screws off and replace the HU, connect your wires, etc.
Thats a quick summary. I dunno if im missing anything but if ya need any more help you can add me on MSN.
Or PM me or just post here. Best of luck
SiG
Old Aug 29, 2004
VP Stylee's Avatar
got it done although i wish i had of seen that wrap it in a cloth sooner hardest part was removing it all. ok ive only got 2 more parts of my system to do, power wire/ground and hooking up the amp to the sub and sub inot the box. alredy wired my remote gain
Old Aug 29, 2004
PopcornPlaya's Avatar
Electric Boogaloo...
you go through this link for the DIY? I know you said you already got it, but I checked and it works fine:
http://www.7thgencivic.com/forums/sh...d.php?t=153830
Old Aug 31, 2004
MegaHurtz's Avatar
this DIY is better and works for the better/newer models
http://www.7thgencivic.com/forums/sh...45&postcount=9
geforce789
Aug 19, 2015 06:17 AM
Misfit2613
Jul 30, 2015 09:49 AM
NoobyKid
Jul 13, 2015 07:53 AM
BootyDo
Jul 7, 2015 06:06 AM
7thgensurvivor
Jul 5, 2015 12:17 PM
