Which AWG wire is ok for a JL 500/1?
Old Aug 26, 2004
MangoEX's Avatar
Just Be
MangoEX should not be trusted
I'm running a JL 500/1 to 2 MTX 8000 DVC 12" subs. I believe the amp is 1,500 w max. I currently have an 8 AWG Monster copper strand wire running off of the battery (from a previous amp) that leads into the trunk. Can I use this wire to power my new amp? or is 8 AWG too thin to handle all that wattage?? I know I'll need to upgrade to a 60 amp fuse right?
And #2, my MTX 8000s, their rating is 400/800, will standard 16 gauge wire be fine? or should I use 8 AWG??? Thanks a bunch!
Old Aug 26, 2004
PopcornPlaya's Avatar
Electric Boogaloo...
500/1 is 500 watts. It accepts up to 4AWG.
Old Aug 26, 2004
darklegacy540's Avatar
darklegacy540 is on a distinguished road
Yes definitely stick with 4awg minimum. Otherwise if you're running a distribution block, it's okay to run 8 as long as the wires aren't longer than a foot or two to the amp.. But definitely 4awg from the battery to the distribution block. Otherwise, just stick with 4awg. It's just easier to be on the safe side.. I even used 4 awg on my 250/1
Old Aug 27, 2004
Civic_Racer9's Avatar
(SnOwBoArDeR | FoReVeR)
change ur power to 4 gauge
and the other one to 12 gauge
Old Aug 27, 2004
MegaHurtz's Avatar
Use the biggest power ands peaker wire that it will accept
Old Aug 27, 2004
Mystic3030's Avatar
Yup, i'm an A$$hole.
4 AWG on the amp and no smaller than 12 for the subs.
The JL 500/1 puts out 500-550 watts RMS at all voltage levels.
Old Aug 29, 2004
MangoEX's Avatar
Just Be
thank you. everything is installed.. doesnt hit as clean as i thought it would, then again, i dont know how to tune an amp. could you guys suggest some good eq settings, gain, etc for my JL 500/1? also maybe it doesnt hit too hard cause i'm using 8 AWG power wire? My friend has these same subs w/ a less powerful amp and they hit a bit harder.
Old Aug 29, 2004
thoughthard's Avatar
thoughthard is an unknown quantity at this point
You're using the 8 gauge after people recommended to upgrade to 4 gauge?
Old Aug 29, 2004
A good start for tuning would be to read through the tutorials located here:
www.jlaudio.com
they have sample system setups as well, and they also have a guide to tuning the 500/1
I can go and write down my settings off my amp (I run a JL 500/1 also) but being as you have different subs, you'd want to tune accordingly (to their specs/frequencies).
Old Aug 29, 2004
doubledeuce2k2's Avatar
things to try:
move box
face box a different way
lower the bass boost (on amp and turn bass down on HU)
lower the crossover setting
drop the rear seat when you don't have passengers (try it once and you'll know why )
Old Aug 30, 2004
That's what I'm wondering
Old Aug 31, 2004
MegaHurtz's Avatar
Maybe he thinks our advice is no good, but of course it isn't, what do we know?
Old Sep 1, 2004
chicohonda02's Avatar
Since 2002 Baby!
i was told to not mess with any smaller than 4 guage
SimpleUser
Apr 24, 2021 02:54 AM
Kevinsisco
Aug 31, 2015 12:04 AM
sch2cm
Jul 21, 2015 09:58 PM
CivicsClass101
Jul 9, 2015 11:14 AM
robbie374
Jul 7, 2015 02:56 AM
