Got new setup, need help wiring?? please!
Old Aug 24, 2004
MangoEX's Avatar
Just Be
MangoEX should not be trusted
I got a JL 500/1 and im 2 MTX Thunder 8000 DVC 12" subs. The subs have a 400rms/800max rating.. anyway the MTX diagram says...
With coils AND speakers wired in parallel:
2 dual 4 ohm speakers will present a 1 OHM load
and..
With the coils wired in series and the speakers wired in PARALLEL:
2 Dual 4 ohm speakers will present a 4 ohm load.
Which route should I take? I want to push as close to the 400 RMS for both subs as possible! Thanks!
Old Aug 24, 2004
Ed's Avatar
Ed
I believe you'll want 4 ohms, the JL does the same power between 1.5-4 ohms, so 1 ohm might not be the way to go. But, it should get the same power regardless.
Old Aug 24, 2004
MangoEX's Avatar
Just Be
Oh really? Wow thanks. So I should wire it the second way.. coils wired in series and the speakers wired in PARALLEL? and i'll get at least 250w x 2 @ 4 ohms??
Old Aug 25, 2004
catalin's Avatar
catalin is an unknown quantity at this point
The best thing to do is get yourself either a 1 ohm capable amplifier or two single 4 ohm woofers. You'll have much greater output this way.
Old Aug 25, 2004
MangoEX's Avatar
Just Be
The MTX 8000s ARE 4 ohm woofers. i'll go the 4 ohm way then! cuz JL regulates the voltage it looks like regardless of impendance
Dani1993
Jul 24, 2015 09:02 AM
Roman Rembacz
Jul 16, 2015 12:30 PM
vtec92
HIDs and Retrofitting
Jul 16, 2015 03:55 AM
CivicsClass101
Jul 9, 2015 11:14 AM
robbie374
Jul 7, 2015 02:56 AM
