weird sub sound
Old Jul 23, 2004
booba5185's Avatar
7thgen Terminator Ninja
booba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to behold
weird sub sound
whenever my 12" dvc kicker hit it almost sounds like theres a paper behind it hitting the cone when it moves, the guy at the audio place said it was distorting, but i have no idea what it is, any ideas?
Old Jul 23, 2004
auto84's Avatar
I R T3H 1338
auto84 will become famous soon enoughauto84 will become famous soon enough
maybe tinsel lead slap.
Old Jul 23, 2004
booba5185's Avatar
what should i do to fix it?
Old Jul 23, 2004
faultyscrew's Avatar
faultyscrew is an unknown quantity at this point
My friends sub did that today - it made me really annoyed - not sure if he noticed or not - I didn't say anything. It just ruined the music. I'm not sure what it is though - I'm no expert - turn the gains down and see what happens
Old Jul 24, 2004
booba5185's Avatar
it sounds fine in the car but when i pop the trunk is where it goes to crap, it's really weird, the guy at the car audio place messed around with my amp and it stopped doing it, but the sub was a lot quieter, so it wasn't hitting as hard, it's just really weird
Old Jul 26, 2004
meseetree's Avatar
meseetree is on a distinguished road
check the size of the box i had the same problem but my box was 1.05 cubic feet and the sub needed only .88 cubic feet so i put some poly-fil in there and it was all better but it was the voice coil starting to go on mine
Old Jul 26, 2004
booba5185's Avatar
this is a brand new sub, i think i found out the problem though, it's max is 800 watts and i'm only puttin 500 to it, so i think it's under powered, but my friend is givin me some blaupunkt 500w amps (2 of em) i was wondering if there's some way to combine the power, i was think of hookin one to each voice coil, but i looked around and found out that it was a biiiig no no
Old Jul 26, 2004
booba5185's Avatar
another reason i think it's under powered is my amp over heats ALL the time, i know i live in phx and it's like 100000000 F out here, but still
Old Jul 26, 2004
MegaHurtz's Avatar
He probably turned your gain down.
My system had a problem like that not too long ago, subs sounded fine in the car, but heinous when you were standing behind the car with the trunk open.
I adjust the level on my line driver and gain on my amp, and all I had after that was a bit of tinsel lead slap on one of my subs. Once I took care of that, they sounded like brand new.
Old Jul 26, 2004
booba5185's Avatar
hmmm, i just noticed that my gain is all the way down at .2v (4v being the top) and the "bass boost" is at like 12 db, so i'm gonn turn the gain up and the bass boost down
Old Jul 26, 2004
MegaHurtz's Avatar
No don't
Gain isn't a volume control, leave it where it is
Old Jul 26, 2004
booba5185's Avatar
i think it's just the fact that i have a crappy amp, a crunch p125.2, wired into 2 ohms, which is supposed to be 500w and the sub's max is 800, i was thinkin of pickin up a 1000 watt amp, i heard over poering a little is good, have i heard right?
Old Jul 26, 2004
MegaHurtz's Avatar
Yeah, it's better than underpowering that's for sure
But not all subs will take a lot of extra power.
Old Jul 26, 2004
booba5185's Avatar
it's a kicker cvr 12, i really wish i could hook up those blaupunkts to it, but u can't hook seperate amps to seperate voice coils, right?
Old Jul 26, 2004
MegaHurtz's Avatar
like 1 amp per voice coil on a DVC sub? of course you can
my buddies Civic has 1 amp per coil on triple voice coil subs and it works like a charm (world record holder).
But I don't know if I'd recommend hooking up 2 different amps to the same sub, just doesn't sound like a good idea to me, but I have no other reason to explain why
Old Jul 27, 2004
booba5185's Avatar
i went out and picked up a bazooka csa300.1 and i'm gonna build a custom plexiglass box in my trunk, that should make it sound pretty good, the amp helped a LOT
Old Jul 27, 2004
meseetree's Avatar
i've got two plexiglass boxes if you want them for a certain fee
pizzahutcombo
Suspension
Jul 13, 2021 09:41 PM
CraigW
Aug 18, 2015 07:06 AM
BootyDo
Jul 26, 2015 10:38 AM
Hqly2001
Jul 25, 2015 05:32 PM
1khilari
Jul 9, 2015 08:12 PM
