about speaker wire guage size
Old Jun 18, 2004
djspot's Avatar
fuk tha man!
djspot is an unknown quantity at this point
not to long ago I had a question about RCA cables...now I got one about speaker wire...
I got a rockford fosgate multi-amp kit...came with a whole bunch of stuff, including the RCA's (which I've come to find out suck), and speaker wire...
the speaker wire is a 16 gauge wire....is that good enough for my mids and highs, and subs...or should I go to a lower gauge for the subs...I heard for the subs I should go for 8-14....let me know...and what should I look for when getting speaker wire??? brands, features, benifits...
THANX in adavance
Old Jun 18, 2004
fonto's Avatar
The LA Clipper
16 is good for mids and highs...I use 12 for my subs
Old Jun 18, 2004
djspot's Avatar
fuk tha man!
cool...like I said, any thing in particular I should look for? other than the guage for the subs
Old Jun 18, 2004
doubledeuce2k2's Avatar
nope wire is wire. RCA's are important, not speaker wire
Old Jun 18, 2004
MegaHurtz's Avatar
Go with a lower gauge for the subs.. 12-10 should be fine
16 gauge is fine for the speakers, especially if they are running off the head unit
I use 12 gauge wire for my subs, and I run a big 1000wrms amp and I've never had a problem
Old Jun 19, 2004
jsbush's Avatar
jsbush is an unknown quantity at this point
Got a question about speaker wire.
Seeing as its important for the RCA wires going to the amp to be shield, wouldn't it also be important for the speaker wire which is run along side the doors to the speakers, to be sheilded as well? Its essentially (depending on your setup) running at same area of your RCA's.
Just a thought. Opinions?
Old Jun 19, 2004
don't worry about shielding speaker wire. avoid when possible, but you won't be able to notice interference in most cases. RCA's are low level (often around 2V max) while speaker wire is the amplified signal (12V or more max)
jru27
Jun 19, 2015 03:51 PM
tkcne
Apr 18, 2015 02:33 AM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
guy
Jan 6, 2002 04:39 PM
