problem: rumbling bass
Old May 18, 2004
diggaflip's Avatar
diggaflip is an unknown quantity at this point
problem... i get a rumbling sound coming from my subs.... this happens sometimes when I play my music kinda low..... also happens when i turn my head-unit off.... my subs jess start rumbling for some reason....... oh yeah, also, before i had subs... i installed 6x9's... and after a while.. i do remember... the 6x9 would also rumble.... wahs wrong? connections? help me out guys.. thanks
Old May 18, 2004
Regularjoe's Avatar
Regularjoe is on a distinguished road
Let me guess .... stock HU.
Old May 19, 2004
doubledeuce2k2's Avatar
do you have a low pass filter set on the amp? also possible
Old May 19, 2004
2k2redcivic's Avatar
2k2redcivic has a spectacular aura about2k2redcivic has a spectacular aura about
if not that check the grounds on everything upgrade if u can. if u do have a low pass filter turn it down a hair it might stop it.
Old May 19, 2004
Regularjoe's Avatar
Generally its when you have a stock HU. It doesn't have a remote lead to tell the amp to shut on and off so you hook it to the ignition. Then when you have the car on, the amp is on. What the issue is, is when the car is on, therefor the amp is on, but you turn the HU off. Now the amp is still on but doesn't know what to play. Basically it just picks up electrical noise in the car and plays it. An aftermarket HU would make it go away mnost likely.
Old May 20, 2004
diggaflip's Avatar
i have a kenwood headunit... excelon 5 somein, forgot..., i know mah headunit has some settings with that low pass filter stuff... ill check dat out
Old May 21, 2004
LudlamTheory's Avatar
i boogie for the raindrops
its a ground problem...
nirvanaguy
25
Oct 26, 2017 07:26 PM
pilebuck13
Sep 21, 2015 10:45 PM
Juanb24
Sep 15, 2015 12:39 AM
Bricoleur
Sep 9, 2015 12:23 PM
Mannimarco
Sep 7, 2015 10:01 PM
