12v(+ & -)
Old Apr 14, 2004
Vteced02civic's Avatar
Vteced02civic is an unknown quantity at this point
12v(+ & -)
Ok, guys i am hooking up my dvd player and i need to hook the 12v wire to a + & - 12v supply. where is the best place to splice into. I was thinking the cig lighter, but dont know what wire is + and what one is -. Any suggestions or help?
jon
Old Apr 15, 2004
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
black wire is ground your negative and the other color is your positive, i believe it is yellow. you can verify with a volt meter before you connect anything
Old Apr 15, 2004
Tre's Avatar
Tre
Tre is an unknown quantity at this point
A voltmeter has saved my @$$ countless times
Old Apr 15, 2004
MegaHurtz's Avatar
Find only the power wire and use the ground bolt located just behind the cigarette lighter as your ground.
h4ldol
Apr 24, 2017 08:16 PM
metalpres
Sep 23, 2015 05:22 AM
Donahue
Sep 9, 2015 05:55 PM
msaeger
Sep 2, 2015 08:47 AM
