sub comparison, need advice
§C§H§O§C§O§B§O
ok guys, need all advice
i'm lookin to replace my stolen system with a similar setup that I plan to bolt down even more securely than before.
i need advice on subwoofers:
here's the 2 alpine ones i'm lookin at
1. swr-1221D
2. swr-1241D
what's the major differences? i read up on them at onlinecarstereo and it doesn't tell me much about the specifications. They confused me with a bunch of techy terms, that just don't cut down to the fundamentals.
help me out guys!
http://www.onlinecarstereo.com/CarAu...roductID=12079
http://www.onlinecarstereo.com/CarAu...roductID=12080
those are the 2 links for the subs...
if you have other opinions, and don't like these subs for some reason, post it and let me know...ive had VERY GOOD experience with the 1st selection, and if there's no much difference between the 2, then i'll get the 1st ones again.
Thanks in advance
1. swr-1221D
2. swr-1241D
help me out guys!
Thanks in advance
No, the ohm difference is simply for wiring options, it has no effect on sound. It can afect damping slightly but I doubt you would ever know the difference.
In the end, what amp you are going to use will determine what sub(s) to get.
2002ExCivic
22
Sep 28, 2015 08:29 AM
PunX
Sep 23, 2015 10:45 PM
